Premix question
03 Jun 2019 17:56
Jagarrett369
Mini Enduro
Mini Enduro
More
Premix question #1
I have a 1974 Yamaha Dt250. The oil pump is disabled and only use premix. The bike is new to me but here goes. I mixed 32:1 and it smokes like a meteor going down the road. What is a safe but non fouling mixture?
My first post here so help me out guys!
03 Jun 2019 21:20
Mothersbaugh
Collector
Collector
More
Premix question #2
32:1 is excellent. Two other things could be causing the smoke. 1) you have a right side crank seal leaking transmission oil into the combustion chamber. Or 2) it sat for a long time and you have an accumulation of oil in the pipe that needs to be burned out over a long ride session.
The following user(s) Liked this Post Enduronut, MarkT, Midlife Motor
03 Jun 2019 21:26 03 Jun 2019 21:30 by Bigdog302.
Bigdog302
Collector
Collector
More
Premix question #3
Jagarrett369 wrote: I have a 1974 Yamaha Dt250. The oil pump is disabled and only use premix. The bike is new to me but here goes. I mixed 32:1 and it smokes like a meteor going down the road. What is a safe but non fouling mixture?
My first post here so help me out guys![/quote
I use 32:1 on my premix on my 2 strokes don't have autolube. it is the best compromise between good engine life and performance. your pipe may be clogged up with two stroke goo. in That case I burn out my pipes with a torch. the bike may had been babied too much and this causes the plugged pipe problem. none of my bikes smoke that much running with the 32:1 oil gas ratio.
Dave
Jesus is Lord!
The following user(s) Liked this Post MarkT
03 Jun 2019 21:34
MarkT
Site Supporter
Site Supporter
More
Premix question #4
Welcome!
Your question is basically opening the proverbial "can of worms" regarding oils and oil mixtures.
Are you sure you mixed the oil and gas correctly? 32:1 is not an excessive amount of oil and I wouldn't go any leaner myself. How many ounces of oil did you add per gallon of gas? (or whatever units of measure you used).
(adding 32 ounces of oil to one gallon of gas is something I've seen before)
Oil type can make a difference... most modern two stroke oils are relatively "smokeless" but you didn't say what you're using.
Running (fuel mixture) rich on premix due to a clogged air filter or something on premix will cause excessive smoke... even the "smokeless" oils tend to smoke a little on a cold engine...
If a bike has been sitting for a long while or just has a lot of old oil deposits it can take a good hard run to clean it out... Not unheard of to have someone jump on a bike that hasn't been ridden in a long time... maybe had extra oil added in storage... ride it 100 feet and proclaim "excessive smoke"... and start making all kinds of changes when the cure might be just riding it good and hard a while. Not enough information given to know.
One important thing is if the clutch side crank seal has gone bad the engine could be drawing in and burning trans oil. Keep an eye on the trans oil level... if you know what the two stroke oil you've chosen for premix smells like when it burns you can often tell a trans leak because most oils used for the trans smell a lot different if burned... usually terrible in comparison. Hard to tell by smell if you don't have experience though.
P.S. It's often when the smoke stops that you have to worry.
The following user(s) Liked this Post Bigdog302, Snglsmkr
03 Jun 2019 21:36
MarkT
Site Supporter
Site Supporter
More
Premix question #5
P.P.S. I type too slow. :haha
The following user(s) Liked this Post Hammer, JayJay
03 Jun 2019 22:55
RT325
Collector
Collector
More
Premix question #6
32-1 is good. Bet money [not much lol] that its just a soak exhaust & needs a burn out or it'll just keep smoking unless you go for a 100mile ride at highway speed. If it was the right side seal you'd be loosing oil into the motor & getting burnt. I guess it smokes that much but still don't think seal because you'd be complaining how bad its running as to be 'that' bad it'd be sucking air plus oil.
04 Jun 2019 03:14
Bigdog302
Collector
Collector
More
Premix question #7
If the Primary side (Clutch side) seal is leaking, the trans oil will be consumed and because of this the smoke itself will hot have the normal two stroke smell, it will instead have a very stinky acrid smell to it.
Dave
Jesus is Lord!
The following user(s) Liked this Post RT325
04 Jun 2019 07:13
Mothersbaugh
Collector
Collector
More
Premix question #8
MarkT wrote: P.P.S. I type too slow. :haha
You type just fine. I just worked the button like the latest Jeopardy champion, who now, I see, has met his match and lost.
The following user(s) Liked this Post Midlife Motor
04 Jun 2019 11:40
Jagarrett369
Mini Enduro
Mini Enduro
More
Premix question #9
Alright, first of all thanks to everyone for the quick responses. I guess I should have been more detailed. I mixed 4 ozs of Casterol 2 stroke oil to one gallon on 87 octane. It started smoking like this after sitting for a couple of hours after a 10 mile ride at 40 mph. Bike is running strong with no miss or loss in power.
Attachment not found
04 Jun 2019 17:21
Brotherman65
Mini Enduro
Mini Enduro
More
Premix question #10
That’s 4 ounces of 2 stroke oil mixed into one gallon of 100% gasoline. 32:1 mix ratio.
TK
