What is my DT100? :)
06 May 2019 03:42
Swoop56
Site Supporter
Site Supporter
More
What is my DT100? :) #11
The Krizman KS 250 stamped on the pipe just relates to the spark arrestor .
It looks exactly like the stock pipe , as do the forks .
The carb will have an ID number stamped on it , likely about the choke tower .
The following user(s) Liked this Post MarkT, clives
06 May 2019 04:38
clives
Mini Enduro
Mini Enduro
More
What is my DT100? :) #12
Thank you Swoop56 - super useful.
06 May 2019 05:01
Swoop56
Site Supporter
Site Supporter
More
What is my DT100? :) #13
Your rear shocks have likely been replaced at some stage with longer units .
There are a few guys here with HT1's , so they may be able to measure theirs ,
to see how they compare . The extra length is what's probably causing the chain
to rub on the swinging arm . I don't think you could buy a small enough front sprocket
to do that .
06 May 2019 20:08
RT325
Collector
Collector
More
What is my DT100? :) #14
I recon the forks are longer than stock plus they don't have the low guard mounts. I dare say they could be removed at the spot welds & forks lowers chr omed but that's unlikely. Front wheel looks like a "21? so someone's been busy.
06 May 2019 20:10
clives
Mini Enduro
Mini Enduro
More
What is my DT100? :) #15
Front wheel is still 19, but I just got a hold of a 21” rim!!!
10 May 2019 21:23
clives
Mini Enduro
Mini Enduro
More
What is my DT100? :) #16
Swoop56 wrote: The Krizman KS 250 stamped on the pipe just relates to the spark arrestor .
What model is this? (I've really tried googling and forum searching)
10 May 2019 23:00 10 May 2019 23:08 by RT325.
RT325
Collector
Collector
More
What is my DT100? :) #17
number 276 relates to yamy HT1 which is what you have.
davesbikes.weebly.com/uploads/4/8/4/5/48...maha_model_codes.pdf
10 May 2019 23:08
clives
Mini Enduro
Mini Enduro
More
What is my DT100? :) #18
RT325 wrote: number 276 relates to yamy HT1 which is what you have.
So via the specs table: a VM20SC ?
10 May 2019 23:09
RT325
Collector
Collector
More
What is my DT100? :) #19
yes i think so.
17 May 2019 22:59
clives
Mini Enduro
Mini Enduro
More
What is my DT100? :) #20
While I’m slowly accruing parts to make the HT1 into a sort of HD Baja/Hodaka Rat styled bike, and get it on the road..., I like to ride it around the lifestyle block. It stopped going last week, and I was 99% sure it was rust blocking jet. So pulled it apart today, cleaned it. Cleaned tank, put in this frankenloop fuel line.
1. Check out the rust that came out of the fuel I took out of the tank. (Yep, that’s a Chemex coffee filter)
2. Sediment pre filter.
I can’t wait for the new tank to arrive (is an AliExpress purchase.
