Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: Nightmares of the Previous Owner
Nightmares of the Previous Owner 08 Jan 2019 20:47 #1
  • Mothersbaugh
  • Mothersbaugh's Avatar Topic Author
  • Collector
  • Collector
Bought this AT-1 in Colorado last weekend. Check out the front brake "service" performed by the PO!
Holy dyslexia, Batman!!
Makes a delaminating brake shoe seem like child's play, doesn't it?
The following user(s) Liked this Post: Benlypage, Snglsmkr
Nightmares of the Previous Owner 09 Jan 2019 03:28 #2
  • Enduronut
  • Enduronut's Avatar
  • Founder Moderator
  • Founder Moderator
Wow . . . almost unbelievable
I also noticed they put the cylinder head on backwards !!
No telling what else you'll find . . . lets hope they didn't rebuild the engine! :whistle:
The following user(s) Liked this Post: Blackhat250
Control your thoughts . . . or your thoughts will control you!.
You can't accomplish . . . what you haven't dreamed!
Last Edit: by Enduronut.
Nightmares of the Previous Owner 09 Jan 2019 05:21 #3
  • asco
  • asco's Avatar
  • Site Contributor
  • Site Contributor
Mothersbaugh wrote: Bought this AT-1 in Colorado last weekend. Check out the front brake "service" performed by the PO!
Seems like the laws they passed in Colorado in the last few years has had “critical mass effects.” So sorry to see that. This generation has totally lost it’s grip.
a
YAMA-LAND
818-521-2109
MINIBIKESERVICE@AOL.COM 1971 125cc AT1-C (DOROTHEA) 1971 175cc CT1-C (BRANDY) 1970 250cc DT1-C (MONICA) 1973 100cc Hodaka Combat Rat (ABBY NORMAL) 1975 DT400 (BONNIE BELL)
Nightmares of the Previous Owner 09 Jan 2019 05:25 #4
  • bike4fun
  • bike4fun's Avatar
  • Sportsman
  • Sportsman
Dang Jim, your bike's PO was a genius. :Ugh
Casper, Wyoming - 76 DT400C, 76 DT175C, 76 TY175C, 75 TY175B (3), 73 RT3, 79 GT80
Nightmares of the Previous Owner 09 Jan 2019 05:43 #5
  • Gr8uncleal
  • Gr8uncleal's Avatar
  • Site Contributor
  • Site Contributor
We must all have our own stories, here's mine for my RT2.
First up, it became apparent that mine had at some stage suffered front end damage – the forks were bent and a non RT2 tachometer was fitted. No problem, forks straightened by Motoliner in Kent and a correct tacho bought from the US.
Now the fun starts!
I decided that I would replace the steering head bearings and races. New ones purchased, old ones removed and new ones fitted. However, the top race was quite loose in the frame and the bottom one was very loose on the bottom yoke/steering column. Not good!
I purchase a brand new bottom yoke and the race sits on nice and tight as it should. I then fit said yoke with no problem. HOWEVER, when I then try and put the forks back on, the holes in the top and bottom yokes don’t line up!
I ordered a brand new top yoke and when it arrived and I compared it with the one fitted to the bike, it was completely different. It lined up fine with the new bottom yoke and I re-fitted the forks. I was still left with the problem of the slightly loose top race and I had to pack out the mount in the frame with thin strips of aluminium (Carlsberg, as you ask!).
I’m only guessing here, but I reckon that the original top yoke was damaged and, instead of fitting a correct one, the PO fitted one off a later model. However, the only way they could get the two yokes to line up was to grind down the steering column and grind out the frame mount where the top race sits. Unbelievable!
Nightmares of the Previous Owner 09 Jan 2019 06:34 #6
  • Mothersbaugh
  • Collector
  • Collector
Enduronut wrote: .Wow . . . almost unbelievable
Thanks! Got that, now. Small fin on the right, long fin on the left. Dead giveaway. I was so busy with the DMV the last two days, I just threw it in the storage unit and slated it for two years from now. But it will be a careful tear down when I get there.
The peeling, flaking yellow paint on the fenders is over the original silver, and it looks like no prep was done. I'm wondering if it isn't latex paint and if it would come off with just an ammonia bath like I'd use for interior hardware that's been painted over in a house.
Nightmares of the Previous Owner 09 Jan 2019 16:32 #7
  • Snglsmkr
  • Snglsmkr's Avatar
  • Sportsman
  • Sportsman
Reverse engineering :silly:
Nightmares of the Previous Owner 09 Jan 2019 20:09 #8
  • asco
  • asco's Avatar
  • Site Contributor
  • Site Contributor
Snglsmkr wrote: Reverse engineering :silly:
Correction: reverse osmosis
a
YAMA-LAND
818-521-2109
Nightmares of the Previous Owner 09 Jan 2019 21:44 #9
  • mdscott
  • mdscott's Avatar
  • Site Contributor
  • Site Contributor
Year back I bought a CT-2 real cheap, the owner said after a new bore and piston the bike ran terrible, no power.......any guess what the problem was?
*it was a real easy fix
Thanks Mark
Roseville, Ca.
'76 Bultaco 143 Frontera
'06 GL1800
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Last Edit: by mdscott.
Nightmares of the Previous Owner 09 Jan 2019 22:03 #10
  • Mothersbaugh
  • Collector
  • Collector
No rings?
  • Page:
  • 1
  • 2
Moderators: DEETDevinDmanEnduronutMakotosunVinnieyamadminJames Hart
