Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
1978 DT400 revs at 4000 rpm on idle
- MotoFrog
1978 DT400 revs at 4000 rpm on idle was created by MotoFrog
Hello everyone!
I’m fairly new to fixing bikes, recently I bought a 1978 DT400. I managed to get the bike running but I have 2 major problems.
First, the clutch doesn’t seem to go past 1st gear. Would this be something that would be easy to fix, I don’t mind having to disassemble the engine.
Second, immediately when I start the bike the engine revs to about 4000 rpm on idle. I don’t think it’s the carburetor because I did adjust the screws but it doesn’t seem to make much of a difference.
Also I’m happy to see there are people that love to keep old bikes alive. I’ve been wanting to work on an old enduro for the longest time and I’m glad I finally got the opportunity!
24 Jan 2023 09:50
- AirborneSilva
Replied by AirborneSilva on topic 1978 DT400 revs at 4000 rpm on idle
Sounds like you have an air/vacuum leak for the high idle. I could be wrong but I don't think the clutch has anything to do with not being able to go past 1st gear, sounds like a problem in your trans, either you clutch works or it doesn't as far as I know. Someone smarter than me will come along to let you know.
1972 DT2 250
1972 DT2 250
The following user(s) Liked this Post: Ht1kid, MotoFrog
24 Jan 2023 10:01
Replied by Ht1kid on topic 1978 DT400 revs at 4000 rpm on idle
Greetings from Tennessee
Is your carb slide stuck not going all the way down have you taken the carb apart? Or air leak as airborne suggested
The following user(s) Liked this Post: AirborneSilva, MotoFrog
24 Jan 2023 15:45
Replied by RT325 on topic 1978 DT400 revs at 4000 rpm on idle
Sounds like you've had the slide out & put it in not aligned with the guide pin. The needle hasd to find its way down the spout of the jet too but i think you have that 'in' & slide likely crosswaus so its resting on the guide pin but in the cutaway side otherwise it'd be reving even harder if say half a turn out.
Regarding gearchange, my guess is the right cover has been off & the change shaft has moved over an inch then gone back on a tooth out of mesh with the change mechanism. especialy if you had the gear lever off at that time so it can move--with right cover off. Link one meshes equaly wth 19 in second link. All a wild guess at the moment.
www.partzilla.com/catalog/yamaha/motorcy...8/dt400e/shift-shaft
www.partzilla.com/catalog/yamaha/motorcy...t400e/shift-cam-fork
The following user(s) Liked this Post: AirborneSilva, Schu, Ht1kid, MotoFrog
24 Jan 2023 15:48
- MotoFrog
Replied by MotoFrog on topic 1978 DT400 revs at 4000 rpm on idle
I really do appreciate the response I’ll check it out this weekend and see what I can find.
25 Jan 2023 09:18
Be sure your lower throttle cable has free play when throttle is closed. Flick the throttle & see if the slide returns to bump the stop-idle speed screw. Then back out the speed screw & see if the slide bottoms out in the carb. Just be sure its all operating freely, & that the oil pump cable isn't hanging things up as that cable can fray going through the adjuster into the pump.
The following user(s) Liked this Post: mx360guy, AirborneSilva, Ht1kid, MotoFrog
25 Jan 2023 13:24
- mx360guy
Replied by mx360guy on topic 1978 DT400 revs at 4000 rpm on idle
Yes check the slide in the carb, Should get a nice thud when you let go of the throttle. The throttle situation must be looked at and you need to be sure all is good throughout from top to bottom.. A stuck throttle is really scary. Good luck!
27 Jan 2023 19:32
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
