locating gear lever shaft
21 Nov 2020 15:05 21 Nov 2020 15:09 by EM ONE.
EM ONE
Mini Enduro
Mini Enduro
More
locating gear lever shaft #1
]Ive been trying to locate the gear lever shaft (see photos)by tapping it on the end into the splines,but to no avail.I dont want to hit it too hard as im concerned that ill bend the selector forks or something in side the cases.Has anybody out there got any ideas. I really dont want to have to split the cases
21 Nov 2020 15:08
1971DT250
Site Supporter
Site Supporter
More
locating gear lever shaft #2
If that is a 250 or 360 I have found that the clutch basket needs to be removed, it is not necessary to split the cases.
21 Nov 2020 15:11
EM ONE
Mini Enduro
Mini Enduro
More
locating gear lever shaft #3
Yes its a 360,and that was one quick reply,cheers for the information ill give it a try
21 Nov 2020 15:16
MarkT
Site Supporter
Site Supporter
More
locating gear lever shaft #4
Year and model is always helpful.
If it's the shaft the shift lever is on, there normally wouldn't be anything "internal"... it's a through shaft.
The following user(s) Liked this Post Rick C.
21 Nov 2020 16:06 21 Nov 2020 16:10 by RT325.
RT325
Collector
Collector
More
locating gear lever shaft #5
If ya trying to put it in, it should slide right home to the selector arm thingy by hand. Are the splines slightly off line. Splines are so fine i'd have thought they'd find there way in without hanging inbetween. If ya trying to remove it then should just pull straight out unless its bent on the let side from being dropped on a rock in a get off in the dirt. If 'that's' the case then fit it back into place & fit a long srong tube over the sticky out bit where gear lever fits but ya tube going right up to the seal--then tweak it accordingly. Works for me.. If you've had the shaft right out the right side i think there's a washer behind that arm which could drop out of the way. Link below to a typical DT1. But i'm wrong damn it--no washer shown, so all good for you Yours look 250 or 360 early model.
www.partzilla.com/catalog/yamaha/motorcycle/1970/dt1c/shifter-b
Having a rethink & a cuppa i guess you mean its bent & won't come out. So parting the cases won't help. In fact you can't part them without straightening the shaft first--in which case you have no reason do part them. Hope that helps [confusing myself lol].
24 Nov 2020 13:04
EM ONE
Mini Enduro
Mini Enduro
More
locating gear lever shaft #6
Managed it,cheers,just removed the clutch basket tapped it into place
The following user(s) Liked this Post MarkT, Mothersbaugh, RT325
