DT1C Wiring Harness
- newt
DT1C Wiring Harness was created by newt
I was wondering if someone could post or msg some pics of proper routing of the original DT1C wiring harness. It 's been a long time since my original bike and I have an original harness and I want to do it as close to factory as possible. I know its a pain to remove your gas tank and all that but I would so appreciate it.
Many Thanks - newt
Many Thanks - newt
27 Aug 2020 16:47
- Badger52
Replied by Badger52 on topic DT1C Wiring Harness
Post #36 from the thread below has a couple pics of tank off on a DT1-B. Should be similar to your bike.
yamaha-enduros.com/index.php/forums/1968...-not?start=30#111627
If you zoom in, there might be enough detail to get you started.
One other tip...the DT1C had two different key switches. Speed and Sport sent me a switch and when I went to install it, the old switch had more wires. After a phone call to them, they sent me the correct one.
Hope this helps you out.
288501A
03 Sep 2020 15:53
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
