Crankcase separation
13 Sep 2019 09:04
bezzer
Newbie
Newbie
More
Crankcase separation #1
I have a 1981 U.K. DT175MX and am about to overhaul the engine, anyone have any advice on separating the 2 halves of the crankcases?, and any further advice on the best puller tool to buy or which to avoid?.
Thanks in advance bezzer
13 Sep 2019 13:24
djr
Mini Enduro
Mini Enduro
More
Crankcase separation #2
when I did mine a few years ago I was changing the con-rod and fitting new crank bearings and seals , the gearbox was fine so I think I left that in one side of the crankcase, as much as possible .
seem to remember using a 2 leg puller on one side of crank { probably flywheel side ? } , but the other side wasn't such a tight fit and puller not required
Advise & things I can remember -
I think the puller I used was just a universal 2 leg car/bike tool , nothing special . { yambits sell a nice 3 leg puller }
you will probably need to get some long bolts to use with the puller ( unlikely to be supplied with puller }
if your not familiar with these engines then dowload or get a paper workshop manual before attempting ( this should also show what tools needed }
use a good sealant on the case join - i used Threebond , but there are others that people will recommend
if it has never been apart before , its now been together for 38 years ! , so may be stuck on corroded dowels & hard sealant
dont be tempted to chisel it apart { a hot air gun & GENTLE use of a soft hammer may help }
make sure all screws are removed, i think there is one which is a bit hidden { how do i know this ? }
Good luck
The following user(s) Liked this Post bezzer
13 Sep 2019 15:19
bezzer
Newbie
Newbie
More
Crankcase separation #3
Thanks djr, some good advice there, like you my intention is to renew the Conrod, bearings and seals etc. I have done many RD/LC twins in the past, but they split horizontally, and I’m yet to attempt a vertical pair!.
