DT2 Wiring help please
12 Sep 2019 11:37
Dave G
Novice
Novice
More
DT2 Wiring help please #1
Apologies if I'm asking obvious questions here!
So in the picture it shows the wires coming out of the engine on my DT2. The four to the left are correct according to the wiring diagrams yellow, green and red, green and black.
But I also seem to have an extra black one and a white - can anyone please tell me what these are?
Also when you connect the battery does it have two leads to the negative - one going to the bike and one to earth?
As you can tell wiring isn't my thing!
12 Sep 2019 11:57
DEET
Moderator
Moderator
More
DT2 Wiring help please #2
Ignore the white and the extra black magneto wire.
12 Sep 2019 12:16
Dave G
Novice
Novice
More
DT2 Wiring help please #3
Thanks Deet
Can you help with the battery question too?
I am going to order all new from you but want to get it up and running quickly as I am going to be racing it in a few weeks.
12 Sep 2019 13:41
Swoop56
Site Supporter
Site Supporter
More
DT2 Wiring help please #4
The Battery Negative wire has a ring terminal , which is fixed hard to the
bikes frame beside the battery box . The frame is then the earth return for
the whole bike . Make sure earth connections are clean . Not a bad idea to
put grease on connection to ward off corrosion .
12 Sep 2019 14:57 12 Sep 2019 15:00 by RT325.
RT325
Collector
Collector
More
DT2 Wiring help please #5
You say 'I am going to be racing it in a few weeks'. Just picking up on this--as if that's your aim then the only wire to worry about is the 'black' from the mag as that supplies the spark to the plug coil. So no battery required & none of the other wires are needed. Just straight to the plug coil with a kill switch for safety & away you go. Tell us more about the racing bit as sounds very interesting.
13 Sep 2019 02:33
Dave G
Novice
Novice
More
DT2 Wiring help please #6
Hi yeah intending to use it for road based events too so need to keep it road legal.
The 'racing' is at the following event
thebikeshed.cc/bike-shed-festival-2019/ they have an off road section run by the following guys
mallelondon.com/the-mile/
The following user(s) Liked this Post MarkT, Badger52
13 Sep 2019 03:34
Gr8uncleal
Site Supporter
Site Supporter
More
DT2 Wiring help please #7
Dave G wrote: Hi yeah intending to use it for road based events too so need to keep it road legal.
Let us know how you get on!
13 Sep 2019 04:09
RT325
Collector
Collector
More
DT2 Wiring help please #8
Wow. I just looked at the links & some videos that led to more videos, i'm hook lol. Trouble is i live half a world away.
The following user(s) Liked this Post Badger52
14 Sep 2019 12:19
Badger52
Site Supporter
Site Supporter
More
DT2 Wiring help please #9
The Bike Shed looks like a good club. Best of luck in the Malle Mile!
288501A
