Oil pump leaking dt 250
04 Sep 2019 15:30 04 Sep 2019 15:44 by Jagarrett369.
Jagarrett369
Mini Enduro
Mini Enduro
More
Oil pump leaking dt 250 #1
Normal for the oil pump to leak at the gasket? Fresh rebuild. Having rev issues as well.
12 Sep 2019 16:45 12 Sep 2019 16:46 by bluntz465.
bluntz465
Site Supporter
Site Supporter
More
Oil pump leaking dt 250 #2
It appears your cable is not adjusted right. The pin should align with the tiny dot on the pulley.Unless of course you checked the output of it. count 200 strokes and you should get 1 ml at idle. and 10 ml at WOT.
I will include a video to help you out as this is a bit tricky to explain on a forum post. I am also guessing your throttle cable is misadjusted and not fully opening,reducing your rev limit. Also a leak is not normal.
1982 Yamaha IT465J
The following user(s) Liked this Post Super90
13 Sep 2019 17:56
bluntz465
Site Supporter
Site Supporter
More
Oil pump leaking dt 250 #3
After your pump is calibrated clean your plug and ride it for a few minutes. Then pull out the spark plug ,take a picture of it and post it back here.
1982 Yamaha IT465J
