DT1 crank case leak and still no spark
15 Jul 2019 20:36
liferbiker
Collector
Collector
More
DT1 crank case leak and still no spark #11
others have told you about seal issues. The blue wire that is below condenser is also to be soldered to condenser, it's coming from points.
15 Jul 2019 20:53
MarkT
Site Supporter
Site Supporter
More
DT1 crank case leak and still no spark #12
There is no drain on the crankcase. When you replace the seal, lay the bike on its side with the old seal out and most of the excess fuel should drain.
If the obvious bad wiring is new and isn't the issue, your "clean" points almost certainly got drenched in fuel and oil the way it's gushing out of that seal and points don't work good wet.
You might consider sending your ignition to DEET once you get it off... he will fix it up and make sure it has spark. Most ones you'll find are going to look a lot worse than yours... "new" is likely impossible to find.
16 Jul 2019 02:10
Nitto05
Open Class
Open Class
More
DT1 crank case leak and still no spark #13
Ok thanks I'll keep ya guys updated
With a strong will you can achieve anything
16 Jul 2019 16:13
Nitto05
Open Class
Open Class
More
DT1 crank case leak and still no spark #14
Update I got one screw out with the impact also the voice grips dont work nor do I have a welder so I'm going to drill and I wasnt sitting with gass nor oil when I got it only a tiny bit was in the trans so cant wait to fix the prob and get it roaring
16 Jul 2019 16:20
Nitto05
Open Class
Open Class
More
DT1 crank case leak and still no spark #15
Guess what
16 Jul 2019 16:24
Nitto05
Open Class
Open Class
More
DT1 crank case leak and still no spark #16
I got a video of the leak with the stator removed
drive.google.com/file/d/1-O9gWwkBZ_utTKo...MQ/view?usp=drivesdk
16 Jul 2019 16:26
Nitto05
Open Class
Open Class
More
DT1 crank case leak and still no spark #17
Now how do I take the oil seal out?
16 Jul 2019 17:26
Mothersbaugh
Collector
Collector
More
DT1 crank case leak and still no spark #18
For the drilled screws, now get a set of left handed drill bits. One a bit smaller than the one you were using should eventually catch and back those broken screws out. Works better than easy outs.
16 Jul 2019 17:28
Nitto05
Open Class
Open Class
More
DT1 crank case leak and still no spark #19
All I did for the first try when I drilled the top out was turn the drilled screw with my finger and It came out i was verry surprised so did the other
16 Jul 2019 17:31
MarkT
Site Supporter
Site Supporter
More
DT1 crank case leak and still no spark #20
Looks like someone made a seal adapter. I wonder if seal they used is a proper dual lip crank seal?
