Rear cog washers/keepers
06 Jun 2019 13:22
meadeam
Site Supporter
Site Supporter
More
Rear cog washers/keepers #1
How important is it to use these? I assume they are to prevent the bolts from backing out. Do you all use them everytime? Mine are pretty banged up after being taken off a few times in this bike's 45 years. I'd just leave them off and perhaps use a bit of locktite unless somebody tells me that would result in certain bodily injury or death.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
06 Jun 2019 13:58
RT325
Collector
Collector
More
Rear cog washers/keepers #2
Good loctite threadlocker will be ok, just don't forget to put it on in the exitement of getting it going/ Use high tensile bolts full length of the threaded hole etc. I see all the bolts out of my old honda car motor are super high 10 strength & pull up nice & solid. I remember at work years ago the supplier of out nits & bolts supplied a bunch of low tensile bolts & was a damn nightmare until we realised what was going on. Just useless cheesy bolts. That reminds me--are nuts of a tensile strength as well as bolts, maybe so but i've never thought that one out. Standard bolts seem to be 8.8 down here in any hardware store,
06 Jun 2019 14:43
Pillsbury
Site Supporter
Site Supporter
More
Rear cog washers/keepers #3
This may be overkill but I replace them with studs, loctite the studs in and then safety wire the nuts :unsure:
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
The following user(s) Liked this Post Giancarlo124, KennyV
06 Jun 2019 17:20
MarkT
Site Supporter
Site Supporter
More
Rear cog washers/keepers #4
Ummm.... talk to GFrench about Loctite and not using the lock plates on the rear sprocket. (Safety wire would be fine)
Probably in a thread here someplace... spoiler: sprocket came loose, loctite did not hold.
Motodad24 on ebay has repop sprocket lock plates for most bikes at a good price... good guy... met him at a Meis event a few years ago.
The following user(s) Liked this Post Snglsmkr
06 Jun 2019 17:34
MarkT
Site Supporter
Site Supporter
More
Rear cog washers/keepers #5
It's been a long day... maybe it wasn't GFrench that had the sprocket bolts back out even with loctite... I do know it's happened to others...
09 Jun 2019 16:35
meadeam
Site Supporter
Site Supporter
More
Rear cog washers/keepers #6
I ended up reusing them. They weren’t as rough as I thought. I’ll replace them next time I take them off for any reason.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
The following user(s) Liked this Post Rick C., MarkT
09 Jun 2019 20:12 09 Jun 2019 20:15 by GFrench.
GFrench
Supporting Moderator
More
Rear cog washers/keepers #7
MarkT wrote: It's been a long day... maybe it wasn't GFrench that had the sprocket bolts back out even with loctite... I do know it's happened to others...
For me.... NEVER Never never run your bike without the washer lock plates or your right Mark- bad things can and will happen.
I tried once not running them and the results could have been very bad... with so much torque and constant applied pressure to the sprocket it takes a lot more than loctite to secure the bolts.
Not going to be a good day if bolts back out and they catch the swing arm and start shearing things off!
Yamaha had a design/ reason for them.
Our friend MotoDad has the best deal going on them/Ebay-
1971 RT1 360 "Black Widow"
1976 IT 400
1978 XT 500
1984 IT 490
