IT175E Project #2
22 Jul 2018 17:33
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #1
Finished tweeking #332 today so moving on to the next one.
This will be a deep clean just like the 1st one. I already know the motor needs a rebuild as it was puarchased with no compression.
If the odometer is correct, & the bike does look like it's fairly low on miles, the owner didn't get much fun out of this one.
I wonn't post as often on this one as it's pretty straight forward & the result should be a nice rider.
The 1st pic's are where this project is getting started. I Canibilized this bike for the YZ swing arm setup for project #1.
Pulled motor & stuffed it back in the corner.
It looks like it got good & hot before it quit & got stuffed in a barn for me to find 40 yr's later....$250.00... :)
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
"And there ya have it"
The following user(s) Liked this Post 2fishkev
03 Aug 2018 13:52
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #2
Gathering parts.....
Monoshock ready to send.....the shock Steve did for project one is working nicely....Thanks Steve....:Buds
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
04 Aug 2018 15:43
2fishkev
Collector
Collector
More
IT175E Project #2 #3
Watching intently..... this oughta be good too.
06 Aug 2018 21:34
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #4
Got these rear shoes over the weekend.
I've never used this style of shoe before so will try them out on this build.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
16 Aug 2018 22:08
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #5
Got the new intake manifold from DC Plastic's today...used one of these on IT #332
This kit is top drawer, everything you need to do a great install...:Throttle
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
The following user(s) Liked this Post bluntz465
31 Aug 2018 21:13
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #6
Ready to rebuild a carb
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
The following user(s) Liked this Post MarkT
09 Sep 2018 19:19
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #7
WOW ! I've been waiting for an evening like this one. Away from the honey do list for a minute.
Of course I had a little extra motivation. Get the cylinder boxed up for shipping to Enduronut.
That meant turning some wrenches...My 1st go at using an air rattle gun to remove the cyl. nuts.
I do believe it's the way to do it from now on.. Anyway a perfect evening...:Buds
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
10 Sep 2018 01:02
RT325
Collector
Collector
More
IT175E Project #2 #8
Gosh, be careful with a rattle gun as think they're alloy long nuts so best use a single hex impact socket rather than double hex normal socket or might jangle the hex off the nut & then you'll be in trouble. Anyway--my rattle gun is a chinese useless one & gives up easy, or my compressor is below par!!. Good old bikes though & had a burnt out one years ago but that's another story. Interesting how wide the squish band is in the cylinder head. Maybe i'm reading the pic wrong but looks super wide with a little bit up in the middle if the piston is following 'that' shape closely--maybe not.
The following user(s) Liked this Post Steve F
23 Sep 2018 17:38
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #9
So the carb rebuild is in progress. Lot's of maple surup was in this one..:Ugh
A couple of unexpected things showed up.
A frozen spring pin in the inlet needle. PB Blaster was called on & successfully broke it loose.:cheer:
The carb must have been apart at one point in it's life, when they reassembled it, they stacked both
baffle gaskets, one on top of the other.:EEEK
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
02 Oct 2018 21:10
Steve F
Site Supporter
Site Supporter
More
IT175E Project #2 #10
Seat is finished...Man Trent, (Ryder68), does great work.:OnFire
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
