Another newbie IT 175 question.
- 69DT-1250
Another newbie IT 175 question. was created by 69DT-1250
So I have another question or 2 for those that know bikes and working on them. Is the number stamped on the right side engine case 650cc, is that the amount of oil that goes in the crankcase? And if that is overfilled would the oil burn and make a bunch of smoke? I just brought home a 78 175 this weekend. It fires up and smokes really bad and smells like burning engine oil like when a four stroke has bad rings. I drained the transmission to see the color of the oil and measured it in my ratio cup. It drained out right around 1400cc of oil.
22 Feb 2021 11:45
Replied by MarkT on topic Another newbie IT 175 question.
That's not "crankcase oil"... it's transmission and clutch oil. Crankcase is lubricated by the oil mixed into the fuel.
You could have a bad crankshaft seal or other issue that allows trans oil into crankcase.
And yes, that's too much oil.
The Owner's Service manual for your bike is in the Tech Library here...
22 Feb 2021 12:28
I don't know if this link will work... yamaha-enduros.com/index.php/ownders-man...t175e-service-manual
For anything about the engine not covered in this manual and/or as a supplement, use the 78 DT175 manual in the service manual section.
The following user(s) Liked this Post: Steve F
22 Feb 2021 12:32
Also, did the oil you drain smell like gasoline at all? If so, that's a sure sign of a bad seal or other leak between crankcase and transmission.
22 Feb 2021 13:34
- 69DT-1250
Replied by 69DT-1250 on topic Another newbie IT 175 question.
I checked the oil out. It’s fairly clean and just smells like oil. No gasoline. Thank you for the heads up on the manual! I was searching around earlier and found specs for different model of bikes. This is a great place for information! I’m thinking about just changing out the crank seals and see what happens. I need to get into the clutch and see what’s going on. Really stiff pulling the lever in.
22 Feb 2021 13:48
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
