Welcome, Guest
  • Page:
  • 1
TOPIC: Started! Almost....
Started! Almost.... 17 May 2019 20:26 #1
  • StukaGruppen13
  • StukaGruppen13's Avatar Topic Author
  • Sportsman
  • Sportsman
Hello gentlemen! Finally, my DT125B started...but only when gas was put directly down the spark plug hole. It started, then died when that fuel ran out. So it HAS to be fuel delivery. I'm checking the reeds out tomorrow, but do any of you have any other suggestions?
- perfectly clean (ultrasonic cleaned) proper Mikuni carb
-new fuel line
-clean tank and petcock
Thanks!
Started! Almost.... 18 May 2019 05:49 #2
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
Is the fuel actually getting into the carb. Pretty easy to fit the float upside down & stop fuel flow. If it 'has' fuel in the bowl it should get to the motor unless something very unusual is happening. Even if all jets were blocked it'd still start on choke with a closed throttle providing that jet is clean but sounds like you given it the ultimate clean [ultrasonic clean]. There's a very slight chance but highly unlikely that one of the crank seals has escaped & putting fuel down the plug hole is igniting it just because the fuel is right where its needed if the piston is above ports closed. Reeds never do anything to stop it running unless the stops have been folded closed or one reed is broken & missing. If it sat for 20 years i suppose they could stick shut with fuel residue. I've run out of ideas sorry.
Started! Almost.... 18 May 2019 06:46 #3
  • Site Contributor
  • Site Contributor
If reeds stuck shut somehow I doubt it would get enough air to run?
Problem is likely in carb or fuel supply to carb... I've had to clean carbs more than once and all it takes is a little bit of debris in a fuel line to plug up the pilot jet.
Started! Almost.... 18 May 2019 08:09 #4
  • DaveR
  • DaveR's Avatar
  • Novice
  • Novice
Make sure the carb slide is not in backwards !
Slide has narrow slot for guide pin, full length of slide.
Notch on other side for idle adjustment screw and only at bottom.
The following user(s) Liked this Post: MarkT, StukaGruppen13
Started! Almost.... 18 May 2019 12:22 #5
  • StukaGruppen13
  • Sportsman
  • Sportsman
Update: Thanks everyone for your suggestions, but I think we've found the issue; vacuum leak. We started the bike and it runs well, except when the choke is off, then the RPMs skyrocket. As well, it takes a while for it to even start. Anything you can image that has to do with starting (spark, timing, fuel supply, carburetor) we've checked, cleaned, and checked again (took the carb to an expert, found nothing wrong) so all that rules out if being something else. Also, we were told that if an excess of smoke pours out of the primary side of the case (where the dynamo is) it is a sign of a leak.
Started! Almost.... 18 May 2019 15:45 #6
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
first thought 'now' is--is the slide hitting the bottom when shut off. Should here it click down when flicking the throttle plus back the speed screw right off so slide is hitting right down. Choke won't work if the throttle is open, well won't like working at kick speed anyway. Major air leak but no major smoke sounds like left crank seal behind mag. But FIRST i'd go looking in the carb & eyeball each jet. Pilot is super small & i use my acupuncture needle to clean it. Remove the needle jet that hold the main jet & look through. Lift the slide needle, put clip on groove 5--the lowest groove, then go try it. Oh, & check the float level to see if its in the ball park. Otherwise yes, a major air leak.
The following user(s) Liked this Post: Snglsmkr, StukaGruppen13
Started! Almost.... 19 May 2019 10:17 #7
  • StukaGruppen13
  • Sportsman
  • Sportsman
We removed the engine (before I saw this ;) ), removed the dynamo and the armature, and lo and behold, massive gap between oil seal and crank shaft. So it was a giant air leak, I'm surprised we even got it started! Thanks for the suggestions and help, I'll have to get a new one, pop it in and reassemble it.
  • Page:
  • 1
