Welcome, Guest
  • Page:
  • 1
TOPIC: DT360 Jet Setter Question
DT360 Jet Setter Question 09 Jan 2019 13:35 #1
  • dnaj11
  • dnaj11's Avatar Topic Author
  • Novice
  • Novice
Have a DT360A with a buggered jet setter, but I'm not ready to give up on the carburetor. The book lists 137-14145-00-00 as the correct jet setter. I cant find one. I see 276-14145-00-00 as available on ebay for the DT250 and DT400, some there say also for the DT360 -but I dunno. Might they interchange? Does anyone have the 137# to spare? Or should I go with the 276? Thoughts? Thanks
DT360 Jet Setter Question 09 Jan 2019 13:52 #2
  • DEET
  • DEET's Avatar
  • Moderator
  • Moderator
Other than the Yamaha parts book, I do not see a 137-14145 in the usual places.
I see a couple of references for the 276-14145 ... and there are several on eBay.
Therefore I would say you should be OK using the 276.
The following user(s) Liked this Post: asco, Snglsmkr
Yamaha@nc.rr.com
DT360 Jet Setter Question 10 Jan 2019 00:45 #3
  • Gr8uncleal
  • Gr8uncleal's Avatar
  • Site Contributor
  • Site Contributor
Further to DEET's reply, the part number on the CMSNL website is 276-14145, as it is in my European parts book.
DT360 Jet Setter Question 10 Jan 2019 06:52 #4
  • dnaj11
  • Novice
  • Novice
That's interesting because the European books have a different part number for the nozzle too! 4451414138 versus 280-14141-30-00, so I wonder if they need to be matched in pairs, each with it's corresponding jet setter, or if they are indeed exactly the same.
DT360 Jet Setter Question 10 Jan 2019 07:30 #5
  • Site Contributor
  • Site Contributor
I wouldn't worry a wink about "matching in pairs". It's a Mikuni and the "main nozzle" is a jet that comes with different inside diameters where the slide needle drops in for tuning purposes and/or different dimensions if the carb body is different. Mikuni threads in the bottom of the nozzle are the same... same threads as a Mikuni hex main jet that is used in "spigot" carbs that don't use a "jet setter".
  • Page:
  • 1
