DT250 Autolube tutorial
11 Dec 2018 15:09
jscott14
Mini Enduro
Mini Enduro
More
DT250 Autolube tutorial #1
I've been gone from this forum for a long time (like 2 years) after my barn find DT250 gave me fits with the electrical. I had DEET redo my magneto (which looks like new now, obviously), but realized AFTER having him do the work that my coil isn't for my DT250. I don't know WHAT it goes to, but it's not my bike. So, just FYI, I have a beautifully restored coil to SOME Yamaha bike if anyone has interest. :)
Anyway, I got my PowerDynamo system all hooked up and the whole system is rewired using a brand new wiring harness. Everything now works 100%! Runs like a top and every single bulb and indicator works. My very last step was to verify the autolube system (since I had just done the test runs of the bike using premix). I couldn't find any great tutorials/explanations on these autolube pumps, so I decided to just make a video on the process.
It's long-winded... perhaps TOO long-winded. But it's not targeted for people who already know how these pumps work. I wanted to simplify the concept of the pumps so that they would hopefully be a bit de-mystified. I just thought I'd share it here. If you have half and hour to burn and want to potentially learn a bit about these little pumps, give it a gander!
The following user(s) Liked this Post Enduronut, Devin, Blackhat250, FrankC, KJB, yamahahaha, Snglsmkr, pabdt, PDXtyist, Zozr, StukaGruppen13, Mr Vegetable Trousers, Camp3, Iwride, Dad637, Von, Trigbe, blazeone
11 Dec 2018 15:48
Zozr
Novice
Novice
More
DT250 Autolube tutorial #2
Great stuff. Can never have too many how to videos for these old bikes. Mine is deleted and running premix right now but I do have a spare pump I might give a shot one day.
Again nice video!
11 Dec 2018 17:28
johninga
Open Class
Open Class
More
DT250 Autolube tutorial #3
Nice description. Thanks for posting. John
11 Dec 2018 19:59 11 Dec 2018 20:00 by MarkT.
MarkT
Site Supporter
Site Supporter
More
DT250 Autolube tutorial #4
Nice video! Awesome explanation of the basic principles! :likey
You saw how that initial cable adjustment can make a difference if the marks are not aligned... It is very easy to have excess cable slack in the lower throttle cable so that the oil pump pulley (or adjuster plate as you call it) rotates quite a bit before the throttle slide starts to lift. So you really need to rotate the throttle grip until the slack is out of the throttle cable and the slide just starts to lift... and then check the alignment of the pin and mark. Not twisting the grip to take up the cable slack at the slide is a common reason for an over-oiling pump on models that have the pump cable adjustment at idle.
P.S. Yamaha specs for many pumps is the same output volume per 200 strokes... it's important to note that this does not mean the pump system on a 250 is identical to the pump system on a 360 or 400. Different size engines have different pump drive gear ratios (often the internal worm gear driving the pump) so the pump on one size engine might be pumping slower or faster at a given RPM than a pump on a different size engine.
So 200 strokes delivers the same volume of oil but at say exactly 1000 engine RPM a smaller engine might reach the 200 count in 45 seconds while a bigger engine with a different internal worm gear might reach 200 strokes in only 35 seconds... Bigger engine is spinning the pump faster and getting more oil at the same engine RPM.
The following user(s) Liked this Post FrankC, Zozr, Dad637
12 Dec 2018 07:37
jscott14
Mini Enduro
Mini Enduro
More
DT250 Autolube tutorial #5
Thanks, everyone! MarkT, I actually thought about bringing up the various final drive ratios of the pumps between the various models, but since it was already too long in my mind, I decided to skip it. Especially since the output values and measurements are still the same.
Regarding the slack in the THROTTLE branch of the cable... THANK YOU! That didn't even dawn on me, and there is a very high likelihood that this isn't going to be right on my bike. I'll dig back into it tonight to double check it. It seems so obvious in hindsight, but I guess that's true of many things in life. Thanks for elaborating on some more of those "gotchas".
17 Dec 2018 12:12
Luke
Site Supporter
Site Supporter
More
DT250 Autolube tutorial #6
Great video! My pump is still in the pile of parts, not yet touched, so this is great prep for future adjustment. Seeing some trial and error is good as well, rather than the 2 minute video with "adjust to factory specs and BAM you're done!"
20 Dec 2018 09:00
AirborneSilva
Sportsman
Sportsman
More
DT250 Autolube tutorial #7
Great video and thank you for making it! I was left scratching my head trying to figure out what in the world they written explanation was trying to tell me, this video made it very clear. I now am confident that I can check my autolube for proper adjustment and if needed make the necessary changes. Thanks again!
20 Dec 2018 13:55
Iwride
Newbie
Newbie
More
DT250 Autolube tutorial #8
Thank you for the video on the autolube pump. The written directions I have seen were very unclear. This has helped a lot.
Also available are small syringes such as 1 milliliter or 3 milliliter to accurately measure the low out put amounts of oil.
22 Dec 2018 06:20
RWag
Newbie
Newbie
More
DT250 Autolube tutorial #9
very helpful! Thanks!
31 Mar 2019 18:25
Scottddove
Open Class
Open Class
More
DT250 Autolube tutorial #10
Is the specs for each bike in the tech library? Specifically the oil amounts that you should be getting at idle and wide open throttle at 200 strokes?
I’d like to check my bikes.
71 CT1
71 RT1
71 DT1
72 JT1
73 LT1
73 CT3
I need some piece of mind.
