Welcome, Guest
  • Page:
  • 1
TOPIC: 74-75 DT175 headlight
74-75 DT175 headlight 07 Nov 2018 12:39 #1
  • Pitobread
  • Pitobread's Avatar Topic Author
  • Newbie
  • Newbie
Hey gent's,
I am wanting to retrofit my RS-100 from a sealed beam but use the oem housing, it is a shared part with the DT175 from 74-75... Just wondering if anyone has ever put any sort of H4 conversion style bulb or housing into of of these. I would like to convert to LED light entirely as my battery is quite small.
Also it appears to be a 5.5-6" bulb, does that wound right?
74-75 DT175 headlight 07 Nov 2018 18:16 #2
  • Site Contributor
  • Site Contributor
If it's the same as the DT175 you can use a 5-3/4" H4 reflector with an LED bulb... search the forum, many threads... including one on an LED bulb that has the fan inside the headlight rather than hanging out the back where it might not clear the bucket.
74-75 DT175 headlight 12 Mar 2019 20:16 #3
  • chhst30
  • chhst30's Avatar
  • Mini Enduro
  • Mini Enduro
Did you find a solution to this? My headlight just blew out and I would like to know what you did. Thanks!
74-75 DT175 headlight 12 Mar 2019 21:13 #4
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
chhst30 wrote: Did you find a solution to this? My headlight just blew out and I would like to know what you did. Thanks!
Suggest you fit a single wire 6 volt Yamaha AC regulator to avoid it happening with the new headlight--can get expensive & damn annoying. If ya headlight has blown the n in theory your speedo & tacho & anything else on direct AC power from the mag will have blown too. Good luck.
  • Page:
  • 1
