Welcome, Guest
16 Jan 2019
Tonight we were hit with a spammer which was caught by Enduronut. The user has been banned, hopefully we will be able to nip this in the bud. Please if you notice spam being posted, shoot an email to me at makotosun1@gmail.com so I can act quickly. Sorry for the inconvenience. apparently our defenses are not perfect. MAKO
  • Page:
  • 1
TOPIC: Rear motor mounts will not budge, tips, ticks, suggestions?
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 07:22 #1
  • oblivionnewtonjohn
  • oblivionnewtonjohn's Avatar Topic Author
  • Novice
  • Novice
Tips, tricks, suggestions to remove rear motor/isolator mounts on a DT100? I've been fighting them for hours.
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 09:28 #2
  • Site Contributor
  • Site Contributor
Remove them from the cases?
My tip: Don't. You will almost certainly destroy them.
If you absolutely must remove them it takes heat and a good press using a pin machined to fit inside the hole as a light slip fit and recessed on the end to clear the center sleeve. I've never been able to hammer them out.
The following user(s) Liked this Post: FrankC, oblivionnewtonjohn
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 09:33 #3
  • Novice
  • Novice
MarkT wrote: Remove them from the cases?
Well great..... I have new ones as one looked kind of gnarly I thought best to replace both. I do not have a press, I will ask on the local Facebook.
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 10:20 #4
  • Novice
  • Novice
These are the ones I have dampner . I see they are press fit, but due to their short size compared to the mounting hole, I thought I would be able to catch the lip of the metal, tap out. Nope, no such luck.
Lesson learned. Hopefully, I can find access to a press or machine shop that can safely get them out, press in the new ones.
Last Edit: by oblivionnewtonjohn.
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 11:45 #5
  • FrankC
  • FrankC's Avatar
  • Solution Contributor
If they are like my 78 400 there is a lip on the case that prevents using a punch to catch the outer sheath. If i am believing the rear isolation dampers. I got out 2 sets on 2 cases by first drilling out the inner spacer, then drilling out the rubber, then prying the rest of the rubber with screw driver. The outer sheath i scored with a dremmel tool in several places, being careful not to go too far and score the case. Then with screw driver i prised away the sheath like opening a can of spam. It was difficult, but no damage to the bore. If i had to do it again i would do what Mark did. Looks like a lot less work.
The following user(s) Liked this Post: oblivionnewtonjohn
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 12:01 #6
  • Novice
  • Novice
FrankC wrote: If they are like my 78 400 there is a lip on the case that prevents using a punch to catch the outer sheath. If I am believing the rear isolation dampers. I got out 2 sets on 2 cases by first drilling out the inner spacer, then drilling out the rubber, then prying the rest of the rubber with screw driver. The outer sheath I scored with a Dremel tool in several places, being careful not to go too far and score the case. Then with screwdriver, I prised away from the sheath-like opening a can of spam. It was difficult, but no damage to the bore. If I had to do it again I would do what Mark did. Looks like a lot less work.
that's what I was thinking.
Rear motor mounts will not budge, tips, ticks, suggestions? 13 Jun 2018 12:01 #7
  • Site Contributor
  • Site Contributor
I've had to do it like Frank did... it's not much fun.
  • Page:
  • 1
