Welcome, Guest
TOPIC: 1974 YAMAHA DT 360
1974 YAMAHA DT 360 04 Nov 2017 20:14 #1
  • asco
  • asco's Avatar Topic Author
  • Site Contributor
  • Site Contributor
I have some very good friends !
Got a text message this morning about 11:00 am about a bike that was listed 30 minutes before. I wasn't feeling good at all. Horrible would describe it accurately. I decided that if I didn't go get it -- somebody else would and then I would feel even worse. If I passed on the bike I would feel even worse. I got the address from the seller's neighbor, since the ladies husband recently passed away and it was his one owner bike. I arrived at about 2:00. Unfortunately, for the last five years the bike is been outside covered, but it had a pink slip and everything was there. The motor is free.
The bikes name has been changed to:
"CROSS-EYED MARY"
asco
The following user(s) Liked this Post: X53flier
YAMA-LAND
818-521-2109
MINIBIKESERVICE@AOL.COM 1971 125cc AT1-C (DOROTHEA) 1971 175cc CT1-C (BRANDY) 1970 250cc DT1-C (MONICA) 1973 100cc Hodaka Combat Rat (ABBY NORMAL) 1975 DT400 (BONNIE BELL)
Last Edit: by asco.
1974 YAMAHA DT 360 05 Nov 2017 07:36 #2
  • asco
  • Site Contributor
  • Site Contributor
My truck was bouncing on the freeway. I did not know that this motorcycle weighs nearly 300 pounds. With a 100 pound versahaul ramp, wow.
At least now I have a plan of attack to get it running. Just doing the basic stuff.
Hopefully the previous owner after going through the garage which happens to have a hot rod in it, which relegated the motorcycle outside will find the following items and contact me. Knowing that it was an original owner and that he was very meticulous about things somewhere in that garage are:
Headlight
Bucket
Ears
Bulb
Rim
Speedometer
Tachometer
Perch
Cables
Tail light
A 2nd. 21" extra front tire.
If all of these items are recovered it will be worth paying the asking price. If not
c'est la vie !
asco
YAMA-LAND
818-521-2109
Last Edit: by asco.
1974 YAMAHA DT 360 05 Nov 2017 07:57 #3
  • Site Contributor
  • Site Contributor
I was wondering because your first post said "everything was there" and the pictures showed a "stripped down for off road" bike... hope the PO finds and you get the street equipment! Looks like a great find in any case! :likey
1974 YAMAHA DT 360 05 Nov 2017 08:12 #4
  • asco
  • Site Contributor
  • Site Contributor
MarkT wrote: I was wondering because your first post said "everything was there" and the pictures showed a "stripped down for off road" bike... hope the PO finds and you get the street equipment! Looks like a great find in any case! :likey
Everything was there meant:
Tool kit
Air box
Cold air boot
Air filter ?
Good seat pan
Wires to headlight bucket good ?
Wires to tail light good ?
Seat better than fair for 44 years.
Clean no rust seen in tank ( drained ) ?
asco
YAMA-LAND
818-521-2109
Last Edit: by asco.
1974 YAMAHA DT 360 05 Nov 2017 13:11 #5
  • asco
  • Site Contributor
  • Site Contributor
Short List:
REMOVE (SOAK) FROZEN PETCOCK
REMOVE (CLEAN) FUEL TANK
REMOVE (CLEAN) CARBURETOR
REMOVE (INSPECT) CLEAN AIR FILTER
REMOVE (INSPECT) BLEED OIL PUMP
REMOVE (INSPECT) STATOR COVER
REPLACE SPARK PLUGS
REPLACE FUEL LINE - FUEL FILTER
asco
START BIKE !
YAMA-LAND
818-521-2109
1974 YAMAHA DT 360 05 Nov 2017 16:20 #6
  • Devin
  • Devin's Avatar
  • Supporting Moderator
  • Cell 805-914-8299
Nice find, Monica has more company now.
1974 YAMAHA DT 360 06 Nov 2017 11:14 #7
  • asco
  • Site Contributor
  • Site Contributor
Great News !
DMV NON-OP TRANSFER COMPLETED
FOR STREET. WILL NEED VIN VERIFICATION AND INSTALLED EQUIPMENT.
THE LADY CALLED, SHE FOUND THE BOX WITH WHAT I HOPE IS ALL THE REMOVED PREVIOUSLY MENTIONED ITEMS.
asco
YAMA-LAND
818-521-2109
Last Edit: by asco.
1974 YAMAHA DT 360 06 Nov 2017 21:02 #8
  • asco
  • Site Contributor
  • Site Contributor
Double post. Nothing from the previous list of things to do has been accomplished.
asco
YAMA-LAND
818-521-2109
Last Edit: by asco.
1974 YAMAHA DT 360 06 Nov 2017 21:02 #9
  • asco
  • Site Contributor
  • Site Contributor
Here's a question for the group ??
What the heck is that chrome loop bracket that is next to the taillight ?
TIA !
asco
YAMA-LAND
818-521-2109
Last Edit: by asco.
1974 YAMAHA DT 360 06 Nov 2017 22:00 #10
  • Enduronut
  • Enduronut's Avatar
  • Founder Moderator
  • Founder Moderator
ASCO wrote: Here's a question for the group ??
TIA !
asco
That's the Yamaha accessory machine gun mounting bracket, that attaches to the front fender . . . . . whistle:
The following user(s) Liked this Post: MarkT, asco, JimA
Control your thoughts . . . or your thoughts will control you!.
You can't accomplish . . . what you haven't dreamed!
Last Edit: by Enduronut.
