Welcome, Guest
13 Jul 2018
I have re-enabled Tapatalk and will try to keep it functional assuming they keep the plug in updated. You can get the mobile app at: www.tapatalk.com/tapatalk_mobile
  • Page:
  • 1
TOPIC: DT175C foot peg alignment
DT175C foot peg alignment 02 Sep 2017 13:32 #1
  • pmgDT
  • pmgDT's Avatar Topic Author
  • Sportsman
  • Sportsman
Looking for a sanity check here. Re-assembling parts on my 175C and very confused about the right hand foot peg/brake lever arrangement.
Seems to me, the tab on the back of the foot peg bracket should be a rest for the top of the brake lever, However, when I have the peg/bracket in the correct upright orientation, the tab is in the wrong place and does not coincide with the brake lever and the brake lever footrest seems to high.
Alternatively, if I turn the peg bracket so that the tab coincides with the brake lever, the foot peg is not in the correct orientation or level.
Not sure if I've assembled something wrong. Any help?
DT175C foot peg alignment 02 Sep 2017 14:40 #2
  • Enduronut
  • Enduronut's Avatar
  • Founder Moderator
  • Founder Moderator
Your not losing your mind . . .
I have several 74, 75 and 76 DT175 models, and they're all that way.
Set the pegs so they're parallel with the ground . . . then
if the lever seems too high for you, you can fabricate (weld) on a lever stop adjusting bolt, or . . .
cut a "shallow" inverted V shape . . . ( ^ ) . . . half way through the forward "lower" side of the lever . . .
Then bend the lever downward until you close up the . ^ . gap you cut . . . and re-weld it.
If you want to reinforce the lever after this mod, you can weld another small plate across the back side of the lever in that area.
One final thought . . . I'd wait until you have the bike back together and ride it, before determining if anything needs to be done about it . . . mine feels fine ... just the way it is.
The following user(s) Liked this Post: MarkT, pmgDT
Control your thoughts . . . or your thoughts will control you!.
You can't accomplish . . . what you haven't dreamed!
Last Edit: by Enduronut.
DT175C foot peg alignment 02 Sep 2017 15:25 #3
  • pmgDT
  • Sportsman
  • Sportsman
Thanks for the feedback Enduronut.
Appreciate it.
Peter
DT175C foot peg alignment 05 Dec 2017 13:46 #4
  • Silo7
  • Silo7's Avatar
  • Mini Enduro
  • Mini Enduro
I’m having the exact same issue, tried to scour web for pics and nothing so far. The tab on peg is worn on mine like it saw contact but there is no way!
Have you found a solution?
Last Edit: by Makotosun.
DT175C foot peg alignment 05 Dec 2017 13:52 #5
  • pmgDT
  • Sportsman
  • Sportsman
Yes and No!
Once I took my head out of my *&@* I looked again and realised my brake lever is completely bent from an obvious historic crash. When I get round to it I'll heat it up and bend it back into shape which should cure the reason the brake pedal sits too high. But as for the tab making contact with the lever I'm still as stumped as ever.
If you work it out before me please report back. And I'll do likewise.
Good Luck
Peter
DT175C foot peg alignment 05 Dec 2017 19:34 #6
  • Site Contributor
  • Site Contributor
Here's some pics of my 1976 DT175c
The following user(s) Liked this Post: pmgDT
DT175C foot peg alignment 05 Dec 2017 19:36 #7
  • Site Contributor
  • Site Contributor
In case it's not obvious in my photos, what hits the "tab" is the kick starter at full swing.
The following user(s) Liked this Post: Makotosun, pmgDT
Last Edit: by MarkT. Reason: clarify
DT175C foot peg alignment 06 Dec 2017 10:13 #8
  • pmgDT
  • Sportsman
  • Sportsman
Thanks Mark.
Isn't funny how these things seem so obvious once you know?
Peter
DT175C foot peg alignment 18 Dec 2017 13:50 #9
  • Silo7
  • Silo7's Avatar
  • Mini Enduro
  • Mini Enduro
Apparently not obvious for me. Engine out during restoration, feeling a bit stupid. Thanks Mark.
DT175C foot peg alignment 18 Dec 2017 14:37 #10
  • Site Contributor
  • Site Contributor
Silo7 wrote: Apparently not obvious for me. Engine out during restoration, feeling a bit stupid. Thanks Mark.
My "not obvious" comment was because of my "not obvious" pictures... certainly not because of you!
(I probably wouldn't have figured it out if I didn't have an assembled running bike to look at!) :Buds
  • Page:
  • 1
Powered by Kunena Forum
