Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: 1974 DT360 Carb
Re:1974 DT360 Carb 04 Nov 2017 15:45 #11
  • Tory
  • Tory's Avatar
  • Mini Enduro
  • Mini Enduro
Canull7004 wrote: Yes I was looking on Sudco and seeVM30-83 that might work. I was looking at the dimensions and I must have wrong airboot. I bought one from CSM and the diameter is 45mm and looks like the VM30's had about 58mm diameter.
I have that issue. My bike was missing the Airbox when I got it and had a cone filter. After sourcing an Airbox and boot I realized the VM30 on it is not original and does not fit the boot.
Struggling to find a proper carb. I have a VM28 of my parts bike 250 but unsure if I can use it, or where to jet it.
I really want to use the right airbix and get away from the cone filter.
Re:1974 DT360 Carb 04 Nov 2017 20:54 #12
  • Site Contributor
  • Site Contributor
Try a PM to member MDScott..... I know he has a DT360 and a DT250. The 360 may have a boot that looks similar to the 250 boot but might have a larger opening to fit on the larger carb? In any case, maybe he can give you the OD dimension of the stock 360 carb.
Re:1974 DT360 Carb 21 Jan 2019 02:20 #13
  • Sllim_Jim
  • Sllim_Jim's Avatar
  • Newbie
  • Newbie
Has anyone had any luck with the replacement carbs?
Picked up a DT360 with no carb and hunting for something suitable. Does anyone know if ( www.mikuni-topham.de/ENGLISHSITE/VM_Carb...VM30-83/VM30-83.html ) this will do the trick?
Cheers
Re:1974 DT360 Carb 21 Jan 2019 11:09 #14
  • Blackhat250
  • Blackhat250's Avatar
  • Collector
  • Collector
Hi jim, these new Mikuni"s seem to be larger than the original VM32, i bought a VM30 and it was bigger inlet and airbox dimentions than the old VM32, it worked well tho, had to upjet as had to put a faom filter on it,Welcome!
If you aint mixin gas " you aint haulin Ass
Re:1974 DT360 Carb 22 Jan 2019 03:20 #15
  • Sllim_Jim
  • Newbie
  • Newbie
Amazing...thanks for the heads up!
Re:1974 DT360 Carb 11 Feb 2019 11:09 #16
  • DouglasDT
  • DouglasDT's Avatar
  • Mini Enduro
  • Mini Enduro
There are at least four 1974 DT360 carbs on Ebay right now.
  • Page:
  • 1
  • 2
