Charge coil question
14 Jul 2019 09:11 14 Jul 2019 09:15 by Don Dieago.
Don Dieago
Sportsman
Sportsman
More
Charge coil question #1
I put a cdi ignition on my dt400 at the time I wasn't worried about charging or lights. Could I possibly in theory put a It175 coil I have just to run the lights headlight and tail? also could I splice a wire from it to rectifier and it would charge battery when lights were off? Ive been charging battery with charger to run tail light and turns for now. Been haveing trouble finding a coil. The original coil wont work with my plate it rubs flywheel
14 Jul 2019 15:16
Don Dieago
Sportsman
Sportsman
More
Charge coil question #2
It will at least run the headlight shouldnt it?
14 Jul 2019 17:09
MarkT
Site Supporter
Site Supporter
More
Charge coil question #3
I'm not sure if the IT175's all had the same lighting coil... they only put out about 30 watts. Pretty weak.
As far as if it will work, only you know what "CDI" you have... (stock CDI should have had a lighting coil so have to guess it's something else?)
The thing is the clearance between the lighting coil poles and the magnets is critical... if the air gap is too big you won't get much output at all... and of course, too small and it will rub. I suspect distance between the coil poles needs to sync with the magnet spacing for best output too.
14 Jul 2019 18:23
Don Dieago
Sportsman
Sportsman
More
Charge coil question #4
I ordered one from rex's and I robbed flywheel off a mx400. They say a later dt will work but not much luck finding one. But I do like their cdi unit a lot. I dont ride at night much at all and I didnt want a 12v. My misjudgment I thought the original early dt400 coil would fit but nope
