'75 DT 100 Runs one day not the next
02 Jul 2019 13:22
Wandwuff
Mini Enduro
Mini Enduro
More
'75 DT 100 Runs one day not the next #1
So i just bought a '75 DT100 with 400 miles on it and it ran when i bought it, then the next day it would only run with the choke on. So i cleaned the carb out and it ran fine so i started to tune it and got it running excellently. The next day it wont start at all other than running for 5 seconds max then dying. The spark is red on the plug if that means something. Any help is appreciated <3
03 Jul 2019 09:44
darinm
Collector
Collector
More
'75 DT 100 Runs one day not the next #2
My guess is that you need to clean the gas tank, and the carb again too. Might be contamination from the gas tank each time you run it right now.
1972 Yamaha CT2 175
1972 Yamaha RT2 360
1972 Suzuki TS 185 Sierra
2001 BMW F650GS
03 Jul 2019 09:49
jims175
Mini Enduro
Mini Enduro
More
'75 DT 100 Runs one day not the next #3
I would get a new spark plug also.
03 Jul 2019 19:03
Wandwuff
Mini Enduro
Mini Enduro
More
'75 DT 100 Runs one day not the next #4
Got a brand new plug, wet plug, still not firing.
03 Jul 2019 21:12
MarkT
Site Supporter
Site Supporter
More
'75 DT 100 Runs one day not the next #5
I was wondering if maybe someone accidentally left the petcock on overnight?
That's usually what has happened to me when I have the symptoms you're describing.
03 Jul 2019 22:19
Wandwuff
Mini Enduro
Mini Enduro
More
'75 DT 100 Runs one day not the next #6
What does leaving the petcock on over night do?
04 Jul 2019 06:50
MarkT
Site Supporter
Site Supporter
More
'75 DT 100 Runs one day not the next #7
Often the engine will get flooded with fuel.
04 Jul 2019 19:52
DT100K
Newbie
Newbie
More
'75 DT 100 Runs one day not the next #8
Don't know if any of this applies to your bike, but here's my experience with one barn find. After the requisite cleaning of the carb to get the bike started (THAT was a glorious day I tell ya), the bike was fouling plugs every 100 miles, even though the bike still sounded lean and was surging at even throttle, despite enriching fuel/air ratio (float height and needle clip adjustments only - I had no alternate jets). Suspected air leaks, but didn't search for them. Did the following blindly simply because the bike had sat for 32 years:
1) replaced the 35 year old paper intake gaskets that were soaked in oil/fuel with rubberized versions. Used gasket sealer.
2) replaced 35 year old copper head gasket and the rubber base gasket that had turned rock hard and was a pain to completely remove. No sealer. Torqued head nuts to spec.
3) properly oiled a replacement air filter. Put grease on the edge that contacted the airbox cover to make a good seal,
4) the rubber boot between airbox and carb was fine but wasn't quite tight on the airbox joint, so applied grease to help seal it from air leaks
All replacement parts were genuine Yamaha. Bike purrs MUCH better now, with no surging, but on the rich side of things (throttle response a bit sluggish now), so put float height and needle clip at stock settings. Perfecto!
Hope this helps.
04 Jul 2019 20:29
Wandwuff
Mini Enduro
Mini Enduro
More
'75 DT 100 Runs one day not the next #9
Well after i cleaned the carb there was no surging and the throttle response was excellent so i don't think there is an air leak. it did foul the plug so bad that it just stopped running sometimes so i leaned it out with the clip. It still wont start after leaving the spark plug out for a day and the gas off so i don't know what is wrong still.
04 Jul 2019 21:02
DT100K
Newbie
Newbie
More
'75 DT 100 Runs one day not the next #10
If the spark plug gets truly fouled, it won't work ever again. Fuel/oil permeates the porous ceramic, which then acts more like a conductor, and the spark goes to the plug's threads, down the cylinder head and into the frame to ground. No spark at electrode, no startey the bikey (which is why I carry a spare plug in the toolkit to get me home).
Were the head and base gaskets replaced or are there 44 year old gaskets present? Your call if you think they don't need replacing....And you really won't know if you have an air leak unless you check for them.....where was it I read, like 60% of running vintage bikes have some sort of air leak????
Does the fouled plug smell like gas or do you think it's oil?
Is there autolube? Is it working? If so, is it set properly? Autolube cable good and not binding?
Weird you are fouling plugs immediately.....
