RS100 lighting troubles
26 Jun 2019 18:19
meadeam
Site Supporter
Site Supporter
More
RS100 lighting troubles #1
Posting here because I am guessing the RS100 has enough in common with the 100-175cc enduros of the same era.
I’ll start by saying this is my first time dealing with electrical issues on a bike. Past bikes I’ve owned miraculously never needed anything more than a bulb change.
Headlight: high and low beams work. Yeah!
Tail light: works
Brake light: tail light cuts out when brake is applied, brake light does not come on.
Signals: no blinks, but come on solid on the correct side.
All of the lights are quite dim, which I suppose is expected. They brighten considerably with engine revs from near invisibility at idle. Bike starts and runs great. I rode it around the neighborhood this afternoon to see if there was any improvement, after running awhile. No changes. I didn’t want to ride too much as I don’t have a plate on it yet
I own a multimeter and am not afraid to use it, but am a novice. I’ll scour the web for info, but if Anyone has a standard procedure they use to solve lighting issues, let me know. This will be a good warm up befor tackling the dt360 wiring and new power dynamo.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
26 Jun 2019 19:58
Mothersbaugh
Collector
Collector
More
RS100 lighting troubles #2
I'm pretty worthless with electricity thus far, but the tail light sounds like you just need a new bulb. The taillight should go out when the brake light takes over, but the brake light filament is burned out. 1157 is the 12 volt version; you probably need the 6 volt version?
26 Jun 2019 20:26
MarkT
Site Supporter
Site Supporter
More
RS100 lighting troubles #3
Sounds like a bad battery or bad ground/connection to me.
Start with your voltmeter at the battery. Should be a little over 6 volts with everything off and battery charged. Activate brake light and/or turn signal. What happens to the voltage at the battery? I suspect you'll see a significant drop?
27 Jun 2019 17:26
meadeam
Site Supporter
Site Supporter
More
RS100 lighting troubles #4
Only 3.2v at the battery. Water was way low too. I filled it up and will charge it. I thought the seller said it had a new battery but I might have imagined that.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
27 Jun 2019 17:33
MarkT
Site Supporter
Site Supporter
More
RS100 lighting troubles #5
Hopefully a top off with water and a charge will fix your issues. Fingers crossed!
27 Jun 2019 21:15
Mothersbaugh
Collector
Collector
More
RS100 lighting troubles #6
Try the epsom salts trick.
28 Jun 2019 07:10
meadeam
Site Supporter
Site Supporter
More
RS100 lighting troubles #7
Mothersbaugh wrote: Try the epsom salts trick.
I don't know that trick. I will ask the google machine.
After a trickle charge, the little battery is at a thriving 7.2v. I didn't have time to try out before work this morning, but hopefully I have fully functional lighting now, and the battery will remain charged with use.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
