Dt175 76 blowing bulbs and now no spark
11 Jun 2019 07:53
Digger65
Novice
Novice
More
Dt175 76 blowing bulbs and now no spark #1
Hi forumers
My dt175 has recently blown a few headlights and yesterday riding home felt like a brief surge of power then stalled..now no.spark at all, rectifier condesor? Many thanks..D
11 Jun 2019 16:17 11 Jun 2019 16:21 by RT325.
RT325
Collector
Collector
More
Dt175 76 blowing bulbs and now no spark #2
Hmm, blowing bulbs shouldn't relate to no spark, well not that i can think of. I'm guessing its a magneto system & not a 125 electric start DC system with a 175 top end fitted?
Yamaha on some early models had a strange way of earthing the ignition source coil in the mag via the lighting coil or coils. Not sure of my facts any more though on that one.
11 Jun 2019 17:09
Digger65
Novice
Novice
More
Dt175 76 blowing bulbs and now no spark #3
Hi thanks
Will get the stator off and see if it is sparking at the points
Just thought the blowing of bulbs might be related
Not getting a spark at the plug now anyhow
Kill switch
Ignition coil
Anything else maybe to look for?
It died pretty quickly, no loss of performance beforehand
Thanks in adv
D
11 Jun 2019 19:44
MarkT
Site Supporter
Site Supporter
More
Dt175 76 blowing bulbs and now no spark #4
If it's truly a 1976 it should have a voltage regulator under the gas tank... would be very rare to blow bulbs if connected and working.
The following user(s) Liked this Post Capt.Dave, RT325
18 Jun 2019 02:51
Digger65
Novice
Novice
More
Dt175 76 blowing bulbs and now no spark #5
..so changed the plug out and braaap it started however wasn't really running right so have changed out rectifier and ignition coil anyways and much better but struggling for air and not revving out, without filter goes like stink, seems like the air filter cage is missing making the filter not sit in the airbox correctly, have magaged to locate a filter cage somehow and will update thanks all D
22 Jun 2019 11:26
Digger65
Novice
Novice
More
Dt175 76 blowing bulbs and now no spark #6
Ok this is where it gets weird..new ignition cpil, plug and regulator, bulb etc, started and ran really well, idled perfectly with loads of braap, couple of days later, no start, spark plug I think is bad again, will spark occasionally on engine casing but only occasionally, plug doesn't look fouled..am thinking maybe too lean blowing out spark plugs? Crank.seals?
22 Jun 2019 11:29
Digger65
Novice
Novice
More
Dt175 76 blowing bulbs and now no spark #7
Oh yeah and it blew the new bulb in 2 mins flat
22 Jun 2019 15:04
MarkT
Site Supporter
Site Supporter
More
Dt175 76 blowing bulbs and now no spark #8
Picture of your regulator and how it's connected would be helpful.
Lots of counterfeit spark plugs out there. Just a possibility if you bought online.
Not likely for a plug to go bad because too lean. Engine damage tends to happen first. It would be nice if plug would fail first. It would be a lot cheaper.
Pictures of plug would help too.
The following user(s) Liked this Post Bigdog302
22 Jun 2019 19:01 22 Jun 2019 19:07 by Bigdog302.
Bigdog302
Collector
Collector
More
Dt175 76 blowing bulbs and now no spark #9
For spark plugs I use NGK in my bikes, if you get non counterfeit NGK plugs they are far less likely to foul than fake NGK and most other brand spark plugs. I have a hunch your bike takes a B8ES NGK plug. here is a link to identifying counterfeit NGK plugs.
Dave
Jesus is Lord!
23 Jun 2019 04:23
Digger65
Novice
Novice
More
Dt175 76 blowing bulbs and now no spark #10
Ok attached image from plug and wiring to regulator
