The Greenie
- Rick C.
Replied by Rick C. on topic The Greenie
So far...
Had to use a hex head to replace a boogered up bolt in this picture. ( may have to trim it to except the stator plate.
Just wanted to wait to sink those darn seals after the 1184 Threebond drys a little, and slam the rest of the parts in for a "test ride " this weekend. But , of course... after a break in.
- Rick C.
Bearing hang up. I don't like it. Ordered a new one.
It all comes apart, again !
Geezo ! more waiting for parts !!
09 May 2020 11:41
#42
Replied by MarkT on topic The Greenie
Crank bearing?
If so, that's why I like to put the crank in the right case with gear bolted on and then pull the cases together from the ignition side.
If it is the crank, a whack with a good size dead blow hammer on the ignition side crank end usually fixes it...
And it might just be "dumb luck" but I've never had to do that it pulling the cases together from the left.
09 May 2020 12:18
#43
- Rick C.
Wish it was that easy Mark. We have a wobble that I don't like. And since all the internals are new, we will concider it " Bad"
Going to change it out.
No Biggie, just dis-heartening.
It's the shift drum roller bearing. PN # 93315-21813-00
09 May 2020 12:31
#44
Interesting... not sure what the "wobble" is... that's not a terribly critical bearing.
09 May 2020 13:17
#45
- Rick C.
New bearing installed, cases glued, Started to put most of the back on and the shift stuff...lost a circlip.
Same black hole loss that most of you all have in your garage. Yeah, me too !
NOT the first time a clippy went, " Ga Zinga Fring " on me. And got lost.
Time to don "the mask" and hit up the local Metric shop !
If they don't have the clippy...Ebay here I come.
- 2fishkev
Replied by 2fishkev on topic The Greenie
I know whatcha mean. Sometimes the only answer is a DEET call... I’ve had help from two semi feral cats awaiting release or adoption before. They like shiny little things, or rusty little things. My things......
21 May 2020 05:38
#47
- Rick C.
Got the clippy.
Special THANKS to my friends at Metric Specialties in Santa Clarita Ca. !!!
www.metricspecialties.com
Things will get happening now.
21 May 2020 12:53
#48
- Rick C.
Special THANKS to T-Bone and Super Dave. ( 3 on a wrist pin..Ha !!. DARN those little clippys ! )
Motor is in, Clutch/ Shifter gears and what not, all is covered and sealed on up. Stator installed , Cylinder and Head torqued.
Not too much time to take bad pictures with the HasbroCam , but I think Dave may have grabbed some.
Tomorrow we put the Mag, Carb Pipe, and chain on, Juice it all up and kick er' over.
Trying to talk him into doing that now. ( 9 PM )
Then just Gas and oil. After we chase the ghosts out of it.
Say 3 Prays for us.
Say 3 Prays for us.
- Rick C.
Now it's just Magneto torqued ,Side cover and shifter, seat and gas tank. also a hockey puck for the splitter on the throttle cable which was ordered and should be here on Tuesday ( Left Denver today . ) Geezo
Major progress today.. a Marathon. Up at 5am.
Everything is smooth as it should be.
Night all, around 11:30pm my time.
21 May 2020 23:41
#50
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
