Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: headlight for my dt discontinued
headlight for my dt discontinued 11 Oct 2018 06:45 #1
  • speedbuff
  • speedbuff's Avatar Topic Author
  • Novice
  • Novice
Since the 6 volt headlight for my 1981 dt 175 is discontinued from Yamaha where could I find one in Canada or the US is there a generic number from a sealed beam supplier or is this thing not readily available? For that matter what about some of the other bulbs like the tail light and turn signals are the generic number for those possibly listed somewhere? Hope I posted in the right area if not pls move this message admin
Last Edit: by speedbuff.
headlight for my dt discontinued 11 Oct 2018 08:34 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
  • Site Contributor
  • Site Contributor
There are a number of options available.
1) Someone like seller id on ebay thevintagespoke offers non Yamaha replacement headlights with, I think, replaceable bulbs. I have not tried these myself and so can't comment either way on quality.
2) When you search for a replacement, also use the Koito ref on the back of headlight unit. Other units of the same size might also fit, but just take care that any locating/fitment screws etc are in the correct place.
Good luck.
headlight for my dt discontinued 11 Oct 2018 21:28 #3
  • Site Contributor
  • Site Contributor
Held in with clips on the later models. I like to use fairly common a 5 3/4" H4 lamp... just remember to use a 6 volt 35w H4 bulb.
Someplace I have a list of bulbs... most are available on Amazon or ebay pretty readily. Some are available in parts stores. It will be a couple days before I can look for it or often the bulbs are marked.
The following user(s) Liked this Post: Pillsbury
headlight for my dt discontinued 12 Oct 2018 05:32 #4
  • speedbuff
  • Novice
  • Novice
Haven't had a look yet just assumed it was a sealed beam?. It would be nice if it was just a bulb . Still messing with the carb/air leak issue . Is there a generic list of bulbs on the site that would be very helpfully?
headlight for my dt discontinued 12 Oct 2018 05:53 #5
  • Gr8uncleal
  • Site Contributor
  • Site Contributor
If it's not a sealed beam unit, then all I can say is lucky you and all you have to do is replace the bulb!
MarkT has mentioned in an earlier post that the headlight should be 35/35w. There should be a stamp just above where the wires clip on to bulb that confirm this, or if it is a slightly lower wattage.
The rear light bulb will be a generic 21/5w, with offset bayonet fitment.
The flasher/indicators will be 18w, but it's no big deal if you fitted 17w or 21w, depending on availability.
The idiot and dash lamps will be 3w but, again, you could use 2.5w or 4w if that's all that you can lay your hands on.
All of the bulbs should be available from an auto/bike store or online.
headlight for my dt discontinued 12 Oct 2018 06:39 #6
  • Site Contributor
  • Site Contributor
Yes as Gr8 says you'd be lucky if it's not a sealed beam now. :likey
I like to replace it with a lens/reflector that has a replaceable H4 bulb.
There are tons of threads on this... I think someone posted this light a while back which is what I would go with when I need another one... pretty slick and easier than getting an H4 reflector and then sourcing the 6 volt bulb... Harley's and Jeeps are two common places the the 5 3/4" lamp is used...
www.thevintagespoke.com/shop/XT500/Elect...26-023-x33558955.htm
headlight for my dt discontinued 15 Apr 2019 21:14 #7
  • ScottMalv
  • ScottMalv's Avatar
  • Mini Enduro
  • Mini Enduro
Just got the 6v H4 light from the Vintage Spoke , went right in, but the bulb burned out within 5 seconds of testing it, then i tried the high beam, it burned out too.
Any thoughts to why? A short? Faulty voltage regulator?
headlight for my dt discontinued 15 Apr 2019 23:07 #8
  • Gr8uncleal
  • Site Contributor
  • Site Contributor
ScottMalv wrote: Just got the 6v H4 light from the Vintage Spoke , went right in, but the bulb burned out within 5 seconds of testing it, then i tried the high beam, it burned out too.
Hello from the UK ScottMalv.
You haven't said which bike you have. If your bike is 1976 or earlier, then it's likely that it doesn't have a voltage regulator fitted and this would be a strong candidate for your headlight blowing out. I assume that you had the engine running at the time?
The official Yamaha Service Bulletin on voltage regulator instalment is in the Tech Library on this forum, but to save you a minute or two I have attached the link to it below.
Regarding the type of regulator to fit, I would suggest that you search the forum for other members' preferences and sources.
Good luck.
yamaha-enduros.com/index.php/workshop/se...e-voltage-regulators
headlight for my dt discontinued 15 Apr 2019 23:51 #9
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
In Reference to ScottMalv, yes i'd guess 'no regulator' as they never really give trouble if fitted. Main cause in the first place is likely to be the battery either not fitted or totally stuffed so can't absorb the excess charge voltage/amperage, but regulator 'saves the bulbs' if a battery fault develops. Battery down here in NZ is only ever for the auxiliary stuff like indicators/stop light/horn/neutral light if fitted etc, but if the battery is out of it then all those things just run on AC--till they blow if ya rev it. All our headlights had replaceable bulbs luckily.
headlight for my dt discontinued 16 Apr 2019 12:53 #10
  • ScottMalv
  • Mini Enduro
  • Mini Enduro
hey thanks guys, sorry, the bike is a 1978 DT 250,
i'm considering ordering the voltage regulator from Rex's SpeedShop RXS100 6V.
the battery is relatively new, and yes, i just started the bike, light was on momentarily, then out.
thanks for the link and advice.
Last Edit: by ScottMalv.
  • Page:
  • 1
  • 2
