Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
Almost Ready for First Start DT-250
  • Mark Serotta
  • Mark Serotta's Avatar Topic Author
Almost Ready for First Start DT-250 was created by Mark Serotta
What should the secondary adjustment be approximately?
So close....
Mark
27 Jul 2022 19:34 #1
Replied by RT325 on topic Almost Ready for First Start DT-250
Just me, but i'd probably start it with the stop screw backed out then set it when running, Mixture i'd just do the usual 1.5 turns out then see how it pans out. That's without knowing what else is going on in the carb of course. But hope it goes to plan. ps, just be sure the slide is touching right down before atempting to start, plus that it opens & returns--same thing as touching down i guess.
Last edit: 27 Jul 2022 19:51 by RT325.
27 Jul 2022 19:48 #2
Replied by MarkT on topic Almost Ready for First Start DT-250
Unless you counted the "big" idle screw when you took it apart, there isn't a "number of turns out setting".  You turn it to where idle speed is correct with engine running.
Little screw to right is the one you lightly seat and then open about 1.5 turns or whatever manual says.
27 Jul 2022 20:01 #3
  • Mark Serotta
Replied by Mark Serotta on topic Almost Ready for First Start DT-250
Do I have it reversed MarkT? I back out the small, screwdriver slotted, one not the large spring loaded, thumb screwknow?
Mark S.
28 Jul 2022 12:26 #4
  • Mark Serotta
Ok. My mistake, I see the pilot is the right side.
I'll back it out.
Regarding the idle adjust, is it:
"Screw Open" = higher revs?
Mark S.
28 Jul 2022 12:42 #5
Replied by AirborneSilva on topic Almost Ready for First Start DT-250
Screw in gives you higher RPMs (idle), the small screw is your air screw and should be set a 1 1/2 turns out, then adjusted from there but at this point it's a good start for you.  You need to do some reading on how to tune your carb...
1972 DT2 250
The following user(s) Liked this Post: Ht1kid, Pedalcrazy
28 Jul 2022 12:52 #6
Umm--thumb screw back it out for safety so it will stop on a closed throttle then once running screw in until you have it idling. But before starting, lightly seat the small mixture screw [screw it in] then back it out 1.5 turns & see how it goes.
28 Jul 2022 15:18 #7
  • Mark Serotta
Update: Couldn't start the 250 this weekend. Plug looked wet, may of flooded it. No leaks from the carb which is good. I plan to put a new plug in and try again.
I sprayed some starting fluid before installing the plug. Anybody else do that?
-Mark
01 Aug 2022 09:59 #8
Replied by DT400FRANK on topic Almost Ready for First Start DT-250
Dont use starting fluid it has no oil in it. Just put a plug in it and start it like normal. If it's very hard to start, something may not be right, be it human or mechanical :)
The following user(s) Liked this Post: 87warrior
01 Aug 2022 11:01 #9
Replied by LETSJET on topic Almost Ready for First Start DT-250
If you use starting fluid squirt the smallest amount in the air cleaner, never heard of it added thru the plug hole. I'd be concerned about a runaway. It should pop, no pop, stop and figure out what else it could be. If all else fails, find a old 2 stroke guy and pay the man.
02 Aug 2022 13:04 #10
