Carb Fitting Remove
- Mark Serotta
Carb Fitting Remove was created by Mark Serotta
My carb, same one that was stuck, has a plastic fitting outside the bowl and stem inside (see pics), obviously an overflow, but can it be removed before a prolong soaking in chemclean?
-Mark
-Mark
23 Jun 2022 18:28
- Mauser
Replied by Mauser on topic Carb Fitting Remove
I think due to it's age it's likely to break off, but I would try boiling water on it to see if once softened up it would come out ?
Yamaha RT2 360 ~ Honda XR650R ~ Yamaha DT175MX ~ Kawasaki KH400 ~ KZ650B3
24 Jun 2022 01:01
Replied by Gr8uncleal on topic Carb Fitting Remove
I would be tempted to leave them as they are.
The black plastic/nylon outer part probably isn't original - it would likely have been brass.
24 Jun 2022 01:04
Replied by MarkT on topic Carb Fitting Remove
On later carbs they were plastic... Best to leave them alone and not dip in caustic cleaner.
Ultrasonic cleaner with mild chems does a much better job anyway in my experience. Properly disassembly allows for fairly thorough cleaning without either.
24 Jun 2022 02:30
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
