1979 DT175 - electrical issues…
- MikeK-uk
1979 DT175 - electrical issues… was created by MikeK-uk
Hi there,
Now having some electrical issues, which seems normal!
When the engine is not running, should the headlight, indicators, horn work at all? Mine don’t.
All was working fine until today….
When engine is running, first symptom was indicators flashing double time. Thought that meant a bulb had failed, but all are flashing, albeit weakly.
Also instruments lights stopped working.
Headlight does not work, but “side / pilot” light and brake light do.
Obviously I can check the wiring for bad connections and bad earths, but wondered if my symptoms indicated a specific problem somewhere.
Also wondering whether I can ride the bike anyway, or whether I could end up broken down with flat battery?!
Any and all advice greatly appreciated!
Thank you.
Mike
Thank you.
Mike
01 May 2022 09:28
Replied by MarkT on topic 1979 DT175 - electrical issues…
Sounds like your battery went bad.
Engine does not need a battery to run... but lights won't work right as you are describing. Not good to continue to ride with a bad battery.
01 May 2022 09:39
Replied by Gr8uncleal on topic 1979 DT175 - electrical issues…
01 May 2022 09:48
- MikeK-uk
Replied by MikeK-uk on topic 1979 DT175 - electrical issues…
Hmm… battery is about 4 weeks old… maybe there is a problem with the charging system. Need to check that then.
And thanks for the welcome!
it would have been courteous of me to introduce myself. I live in the UK and wanted a DT when I was a kid. Many years later have had my ‘79 175 for about 5 weeks now. Really enjoy riding it, and problems such as this are to be expected, with mine being a survivor bike rather than something that has been rebuilt.
01 May 2022 10:19
- MikeK-uk
01 May 2022 10:21
- Pete-RT1
Replied by Pete-RT1 on topic 1979 DT175 - electrical issues…
Hope you get the electrical issue sorted.
I love a DT175MX, my first bike aged fifteen.
Yamaha RT-1
Yamaha CT1-B
Yamaha CT3
Yamaha CT1-B
Yamaha CT3
01 May 2022 10:24
Wait for other UK DT175MX owners to confirm, but I would suggest that lights should come on, even if engine not running (second position round on the ignition switch?).
It's probably worth trying to find a service manual for your specific model, as that will provide you with details of the wiring diagram, as well as the electrical components fitted and how to test them.
01 May 2022 10:43
- MikeK-uk
So no load battery voltage was 4.9V with bike not running. Too low. The voltage collapsed when I turned an electrical load (bike still not running). Started bike to measure charging voltage… was 12.5V. So my guess is goosed regulator and a boiled battery?
01 May 2022 10:47
It's possible I'm misunderstanding what works and when... but if battery powered accessories such as indicators, horn, etc at least try to work, albeit weak, only with engine running it indicates the charging system is okay and somehow the battery is not supplying reserve power as it should.
Could be a bad connection to battery but it's not uncommon for batteries to fail from vibration or just poor quality... most aftermarket original types only have a 30 day warranty for a reason. Yuasa Japan batteries are the ones I've had the best luck with... or something like a Motobatt.
01 May 2022 10:55
Your reply snuck in when I was posting.
You might have blown some bulbs... battery acts as sort of a rudimentary regulator which is why it's bad to run without or with a bad one.
Make sure regulator (should be mounted on bottom left side of air/battery box, single yellow wire) is connected and has a good ground wire attached to one of the regulator case mounting bolts. I've seen a few where regulator ground wire is missing which makes regulator useless.
01 May 2022 11:02
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
