34mm carb
  • morty911
  • morty911's Avatar Topic Author
34mm carb was created by morty911
I purchased a 34mm VM34-275 from Dennis Kirk for my 78 DT400 ,I know I will have to rejet it. My question is there is no port for oil injection can and where do I puy a port in for the oil injection.
Thanks for any help
Mort
23 Jul 2021 14:57 #1
Replied by Gr8uncleal on topic 34mm carb
Yambits (UK based) do this part for the RD models, although I'm not familiar enough with your carb to say whether or not it would do the job. I think that Sumo Rubber also stock something similar.
I think that both companies might be out of stock at the moment, though.
Yambits : RD350 Carb Oil Line Injector Elbow
Last edit: 24 Jul 2021 00:07 by Gr8uncleal.
24 Jul 2021 00:07 #2
  • morty911
Replied by morty911 on topic 34mm carb
thanks
24 Jul 2021 07:41 #3
Replied by Lizeec on topic 34mm carb
I did the same conversion to a Mikuni VM28 for a 1976 DT250C, I have a thread on here detailing the conversion. This is the part I used, I preferred the threaded vs. press fit version. On the carburetor I bought it had a cast in boss on the right hand side that appears was cast in the carburetor housing for this exact conversion.
Genuine Mikuni Thread In Primer Nozzle Port Oil Injection Barb Spigot VM34/181
Buy It Now
Last edit: 24 Jul 2021 08:23 by Lizeec.
24 Jul 2021 08:15 #4
  • morty911
Thanks that helps
24 Jul 2021 08:36 #5
  • morty911
Which boss the upper or lower?
24 Jul 2021 08:38 #6
What you are referring to is on the actual carburetor body? I used the little dimple inside the square on the spigot itself, if you look at your original carburetor where the oil line port is it just feeds the oil into the spigot, almost exactly where the dimple inside the square is.
Last edit: 24 Jul 2021 12:49 by Lizeec.
24 Jul 2021 12:48 #7
Replied by RT325 on topic 34mm carb
No recommending my fix but, "my fix" many years ago was just hooked the pump to a breather fitting high up on one side of the carb i was using. Think it had a breather both sides plus one from the bowl--overflow breather-- Pumped into the breather & dropped into the bowl so mixed as you went. Worked for me.
The following user(s) Liked this Post: DT400FRANK
24 Jul 2021 16:48 #8
