Aftermarket carb for 78 DT250
  • smk8954
  • smk8954's Avatar Topic Author
Aftermarket carb for 78 DT250 was created by smk8954
I recently bought a 1978 DT250 from someone that converted it to premix and disconnected the autolube but left the system in tack. The issue I ran into is that they plugged the oil inlet in the carb with a screw leaving it threaded. I am tempted to attempt to drill it out but as the original carb has been discontinued, I was wondering if anyone had a suggestion for an aftermarket carb I could replace it with should it be necessary.
15 Mar 2021 16:15 #1
Replied by elliottles1 on topic Aftermarket carb for 78 DT250
hi,
i have had great success with the OKO, kehin copies on ebay from china, the flat slide power jet type. they are only about 25 quid and are good quality and very easy to jet. i have used 4 on different bikes including dt250 and 400, 32mm and 34mm respectively and wouldnt hesitate to use them again.
cheers
les.
Last edit: 10 Jun 2021 12:04 by elliottles1.
10 Jun 2021 12:04 #2
