Re:Re:Re:Re:Re:1977 DT400 CDI Box question
  • Thebassguitarist
  • Thebassguitarist's Avatar Topic Author
1977 DT400 CDI Box question was created by Thebassguitarist
With many headaches of my bike not running right I realized I overlooked a major aspect. Timing. Upon strobing my running motor at idle the strobe is all over the place. It's incredibly inconsistent and never lines up with the timing marks.
I remember reading something a while ago that this failure can be blamed on the CDI box? Am I right in that diagnosis?
Sent from my E6910 using Tapatalk
19 Feb 2021 11:42 #1
Replied by MarkT on topic 1977 DT400 CDI Box question
It's possible it's the CDI box...  but often it seems to be the stator.
One thing to try is to take apart and clean all the wiring connections and grounds.  More than one "inconsistent" CDI problem has been fixed by cleaning up connections and grounds.
19 Feb 2021 13:36 #2
  • Thebassguitarist
Replied by Thebassguitarist on topic Re:1977 DT400 CDI Box question
Will do.
If that doesn't work is there a good way to diagnose between the stator and the CDI box?
Thank you for all of your help Mark.
19 Feb 2021 13:57 #3
Replied by MarkT on topic Re:1977 DT400 CDI Box question
There are some cursory checks that can be done with an ohmmeter...  Service Manual in Tech Library details them.
Unfortunately I've had component test perfectly with a meter but CDI doesn't work right...  Yamaha's answer was "replace with known good" which was easy for the dealer to do when these bikes were new and parts were on the shelf or maybe another bike was available to swap parts with...  Not so easy today.
19 Feb 2021 14:54 #4
  • Thebassguitarist
Replied by Thebassguitarist on topic Re:Re:1977 DT400 CDI Box question
Hopefully a friend with a known running dt250 will be kind enough to let me borrow some parts.
19 Feb 2021 15:36 #5
Replied by MarkT on topic Re:Re:1977 DT400 CDI Box question
DT250 would have had points unless friend has a 1979.
The following user(s) Liked this Post: Blackhat250
19 Feb 2021 16:14 #6
  • Thebassguitarist
Replied by Thebassguitarist on topic Re:Re:Re:1977 DT400 CDI Box question
It's a 77. I was under the impression they were the same as the 400. Bummer.
19 Feb 2021 16:16 #7
Replied by Schu on topic Re:Re:Re:1977 DT400 CDI Box question
Hold that thought........
When you get tired of messing with your CDI issues you may once again be looking for 250 parts. I swapped away from CDIs on my 360 and my 400. I've been happy with it ever since. They start easier and run better now than they did with the CDIs.
CT175B, CT175C, JT1' JT2' DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
19 Feb 2021 16:32 #8
  • Thebassguitarist
Tested my charge coil. Service manual says it should read at .33 (I assume ohms) plus or minus 10% and I'm reading 154 ohms. So bad coil then?
19 Feb 2021 16:40 #9
  • Thebassguitarist
Just read on another thread that the dt400 is supposed to be 120ohms plus or minus 10%
19 Feb 2021 16:50 #10
