Low Oil Indicator Light
23 Feb 2020 14:10
C Team
Novice
Novice
More
Low Oil Indicator Light #1
So I'm slowly getting this barn find 1978 DT125E back to running condition but having an issue with the low oil indicator light staying on in the tach gauge. I pulled the float switch out of the oil injection tank and the float is free. I also unplugged the float switch to check if the light on the tack would go out and it did. I installed the float switch back into the oil tank, hooked up the wires, filled with oil and turn on the key. The light is still staying on. So i guess I try to find a float switch or just live with the light always staying on.
Any suggestions?
Thanks!
23 Feb 2020 16:26
Devin
Supporting Moderator
More
Low Oil Indicator Light #2
In neutral, the light will always be on. They designed it this way so you know if the light is working.
The following user(s) Liked this Post Enduronut, Makotosun, MarkT, FrankC
24 Feb 2020 03:01
C Team
Novice
Novice
More
Low Oil Indicator Light #3
That is good to know! Thanks for the tip!
24 Feb 2020 03:24
Gr8uncleal
Site Supporter
Site Supporter
More
Low Oil Indicator Light #4
That has been known to confuse quite a few new owners!
24 Feb 2020 03:28
C Team
Novice
Novice
More
Low Oil Indicator Light #5
Well it sure had me confused! :)
The following user(s) Liked this Post FrankC
24 Feb 2020 16:30
FrankC
Solution Contributor
More
Low Oil Indicator Light #6
I have a 78 400 on that my neutral light is burned out, so I use the low oil warning light as a neutral of sorts.
