Flywheel magneto wiring
17 Oct 2019 11:50
jacks3
Newbie
Newbie
More
Flywheel magneto wiring #1
Attachment not found
Hello to all
Some time ago I've bought a DT 250 ('78 or '79?) and I'm trying to restor. I'm now at wiring phase. I was also lucky to buy complete engine where FWM wiring is not matching with a diagram. Colors a re completely different than on wiring diagram and different than in old engine. To not burn anything I need your help guys. Do somebody may take a look on attached sketch and give me some advice?
Ah, almost forgot, my main wiring seems to be like DT400...
17 Oct 2019 12:23
Gr8uncleal
Site Supporter
Site Supporter
More
Flywheel magneto wiring #2
Welcome! jacks3.
Looks like your photos didn't upload properly - would you have another go?
Thanks.
17 Oct 2019 20:40
RT325
Collector
Collector
More
Flywheel magneto wiring #3
If It's "79 it'll have CDI Ignition. If it's magneto that i thought finished in "78 it'll have a Black only coming from the mag to run the ignition, or maybe black/white further up. I can't remember now but think cdi has either a black with red tracer only for the source, or could be a brown only. Trigger [pulse] coil will be white with a red tracer. Sorry if this has been covered. Wrote it earlier & forgot to push send.
18 Oct 2019 09:38 18 Oct 2019 09:50 by jacks3. Reason: problem to upload photos
jacks3
Newbie
Newbie
More
Flywheel magneto wiring #4
I've tried several times to upload photos and don't know why was unsuccesfull ...
I'll try again
18 Oct 2019 10:00 18 Oct 2019 23:32 by jacks3.
jacks3
Newbie
Newbie
More
Flywheel magneto wiring #5
Hi RT325
The main wiring have one connector with three wire and additional three free wires at engine side. connector with three wires have round pins and the free wires too.
08 Nov 2019 08:55
jacks3
Newbie
Newbie
More
Flywheel magneto wiring #6
Hi again
Guys, I really need your support please ;-)
thanks in advance
08 Nov 2019 09:37
Gr8uncleal
Site Supporter
Site Supporter
More
Flywheel magneto wiring #7
What part of the world are you located in and what are the engine numbers?
09 Nov 2019 05:57
jacks3
Newbie
Newbie
More
Flywheel magneto wiring #8
Hi Gr8uncleal
I'm from Poland. I have two engines as you may see in my previous posts. According to them:
1. New engine: *1R7-200359*
2. Old engine: *1R7-001925*
I hope it will help and maybe some support be possible.
thank you in advance and regards
jacek
09 Nov 2019 06:52
Gr8uncleal
Site Supporter
Site Supporter
More
Flywheel magneto wiring #9
Thanks.
1R7 is model code for DT250MX Europe, 1977 and 1978.
Not that it's relevant, but was the bike imported from Germany at some point?
The colour of the wires on the old engine is close to that of the US 1978 DT250E, for which there is a wiring diagram in the Tech Library - I have attached it here for convenience.
I'm not sure about the wiring on the new engine!
Are you able to post photos of the new and old stator plate/generator and also of the wiring connectors on the main harness of the bike.
Finally, and I should have asked this before, what is the frame/VIN number of the bike?
This message has an attachment file.
The following user(s) Liked this Post MarkT
09 Nov 2019 07:26
MarkT
Site Supporter
Site Supporter
More
Flywheel magneto wiring #10
The problem for me is Yamaha tended to be extremely consistent on wire colors.
Your "new" wiring colors do not appear to follow the normal Yamaha colors at all. It might be from a different bike completely. The ignition systems were made by suppliers like Mitsubishi, Hitachi, and Kokusan and it is sometimes possible to fit a complete Kawasaki or Suzuki or even Honda ignition stator and flywheel to a Yamaha. This is somewhat likely as the newer engine probably originally had a CDI system and is now points. Not uncommon as the CDI's fail and parts can be expensive or even impossible to find.
Can't you simply install your original ignition system onto whichever engine you are using?
