Welcome, Guest
TOPIC: Finally joining the cool kids - DT1? Build
Finally joining the cool kids - DT1? Build 10 Apr 2019 06:54 #21
  • Sonreir
  • Sonreir's Avatar Topic Author
  • Mini Enduro
  • Mini Enduro
More tear down finished last night. I also got the frame de-tabbed since I'll be running the aftermarket seat and no original side covers.
I found an interesting rear spacer when the wheel came off and the brake cable holders on the the front and the rear wheels are both broken. The rear wheel is also dented (which I hadn't noticed before).
And for some reason, some one got a bit crazy with an angle grinder up front.
Up next is engine disassembly.
Finally joining the cool kids - DT1? Build 15 Apr 2019 09:32 #22
  • Sonreir
  • Mini Enduro
  • Mini Enduro
The previous owner went crazy with an angle grinder, so I figured one good turn deserves another. Flipped the wire feed welder into low voltage mode and started filling in the gouges. Definitely not perfect, but it's an improvement. I might go over it one more time before I hit it with the flappy-sanding thingy.
Engine tear down started and I broke the clutch basket, so time to hit eBay again. I got the usual number of stuck screws and will need to drill a couple of them out.
Finally joining the cool kids - DT1? Build 15 Apr 2019 11:54 #23
  • DEET
  • DEET's Avatar
  • Moderator
  • Moderator
You should be using the DEET clutch hub holding tool.... then you won't break the ears off.
The following user(s) Liked this Post: Sonreir, Snglsmkr, Pillsbury, Ethan
Yamaha@nc.rr.com
Last Edit: by DEET.
Finally joining the cool kids - DT1? Build 16 Apr 2019 07:20 #24
  • Sonreir
  • Mini Enduro
  • Mini Enduro
A little bit of welding and a lot of grinding later, I have an electronics tray. I still think I want to work out some sort of cross brace near the shock mounts, though...
The following user(s) Liked this Post: Giancarlo124
Finally joining the cool kids - DT1? Build 17 Apr 2019 06:59 #25
  • Sonreir
  • Mini Enduro
  • Mini Enduro
I started on cleaning up the rear fender last night. I went over it with an orbital sander and 320 grit. Hand sanding starts tonight.
Finally joining the cool kids - DT1? Build 18 Apr 2019 15:36 #26
  • Dirtboy
  • Dirtboy's Avatar
  • Sportsman
  • Sportsman
looking good Sonreir!
Finally joining the cool kids - DT1? Build 19 Apr 2019 10:42 #27
  • Sonreir
  • Mini Enduro
  • Mini Enduro
Hand wet-sanded through to 1000 grit and then hit it with some plastic polish. Good enough for something that's going to be covered in dirt and mud anyway. :P
