Welcome, Guest
18 Feb 2019
Sorry - I had to take the site offline for about 15 minutes tonight. Emergency repair. Please review the Site Upgrade Post for more information which will affect you. It's all good.
  • Page:
  • 1
TOPIC: DT2 Torque settings and clutch springs
DT2 Torque settings and clutch springs 10 Feb 2019 14:41 #1
  • DT2XC
  • DT2XC's Avatar Topic Author
  • Mini Enduro
  • Mini Enduro
I could use some advice on DT2 Torque settings. I do have a Clymer manual...but some of the info needed is missing:
1. 19mm Mag flywheel nut: manual says 28 ft lbs...that seems low to me
2. 29 mm nut on rh (primary gear) end of crank
3. 29 mm nut on clutch inner hub.
Also...manual says length of clutch springs is 36mm, replace if 35mm or less. Mine are ~ 34mm...but all are same length and they do not appear weak...any advice?
DT2 Torque settings and clutch springs 10 Feb 2019 15:16 #2
  • Mauser
  • Mauser's Avatar
  • Sportsman
  • Sportsman
Clutch springs were under size on the RT2 according to the "Book" I would ignore the sizes quoted.
RT2 ~ XR650R ~ DT175MX ~ ZX12R ~ XJR1300 ~ DT125LC ~ XR250R ~ XL125R ~ RD350LC ~ MT50 ~ GPZ1100
  • Page:
  • 1
