Welcome, Guest
  • Page:
  • 1
TOPIC: 1972 Yamaha CT2 175 - Ignition Assembly
1972 Yamaha CT2 175 - Ignition Assembly 12 Sep 2018 11:40 #1
  • CKO21
  • CKO21's Avatar Topic Author
  • Newbie
  • Newbie
Hi All,
New to bikes and just started working on a 72 CT2. The Ignition Assembly (Where you put the key in) was falling apart and I found an original unused assembly to replace it with. Used to be able to turn the lock with a screw driver or even a penny to turn it on. I've installed it but now I can't get the headlight, taillight/brakelight and directionals to all work at the same time. When I turn the key to the first position the directionals work when I turn it to the second position only the headlight and tail light work. Is this normal? Is it a battery issue? Any advice is greatly appreciated.
1972 Yamaha CT2 175 - Ignition Assembly 12 Sep 2018 15:05 #2
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
Too early in the day for me to think clearly lol but if you've fitted a second hand switch it's possible someone's had it apart to clean the contacts inside & reassembled it half a turn out. I think you get two shots at the internal bits with the plates that bridge the contacts so you'll either get it right --or wrong, sounds wrong. Been 45 years since being in one lol but think you have two screws on the underside, or 3 screws!!. Ignore me if i'm not reading your story right & others will weigh in soon. Cheers.
The following user(s) Liked this Post: CKO21
1972 Yamaha CT2 175 - Ignition Assembly 12 Sep 2018 15:12 #3
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
also--being ct2 i dare say the lights are magneto not battery but not sure about tail light ion the usa, down here in nz tail light is magneto too. blinkers & stop light & horn--neutral light if fitted are battery, but if battery is flat the mag lighting coil will try to run them when motor running although with lights on and brake applied it;ll drag the lights down. also with a stuffed or empty batter you stand the chance of blowing the headlight at revs and a single wire regulator is a good update--bulb saving regulator that is. anyway--if it was ok prior to switch change then it sounds like a mainly switch issue--ok i'm outa here for the day. ps, guessing ya in the usa.
1972 Yamaha CT2 175 - Ignition Assembly 12 Sep 2018 16:30 #4
  • Site Contributor
  • Site Contributor
What country you are in matters... for the US with regard to lights:
In position 1, the brown and red (battery) connect which makes the flashers and horn work.
In position 2, the brown and red are still connected along with the blue (L) taillight wire. (This is because the US requires the taillight to stay on if engine dies.) The headlight only comes on with the engine running and is powered by the yellow (AC power from stator) connecting to another blue that runs the headlight and gauge lights. (In other countries this circuit also runs the taillight.)
Does your headlight come on without the engine running?
Here is a chart from the CT2 wiring diagram showing what wires connect in the different key positions. Full diagram available in service manual in Tech Library.
1972 Yamaha CT2 175 - Ignition Assembly 12 Sep 2018 20:10 #5
  • Mothersbaugh
  • Mothersbaugh's Avatar
  • Collector
  • Collector
RT325 wrote: If you've fitted a second hand switch it's possible someone's had it apart to clean the contacts inside & reassembled it half a turn out. I think you get two shots at the internal bits with the plates that bridge the contacts so you'll either get it right --or wrong, sounds wrong.
More possibly, someone has inverted the plate in the switch that turns left and right. I had a CT-1 that was exactly backwards in how the unit worked, what it turned on, and the top plate was on upside down. Flipped it over, and everything worked as desired.
The following user(s) Liked this Post: Hammer, CKO21
1972 Yamaha CT2 175 - Ignition Assembly 13 Sep 2018 13:21 #6
  • CKO21
  • Newbie
  • Newbie
Thanks, I'm in the US.
1972 Yamaha CT2 175 - Ignition Assembly 13 Sep 2018 13:21 #7
  • CKO21
  • Newbie
  • Newbie
I'll try flipping the plate and see if it fixes the problem, thanks!
  • Page:
  • 1
