Welcome, Guest
13 Jul 2018
I have re-enabled Tapatalk and will try to keep it functional assuming they keep the plug in updated. You can get the mobile app at: www.tapatalk.com/tapatalk_mobile
  • Page:
  • 1
  • 2
TOPIC: Left switch assembly indicator assembly
Left switch assembly indicator assembly 12 Oct 2017 12:39 #1
  • Chajoma
  • Chajoma's Avatar Topic Author
  • Novice
  • Novice
My At3 has no indicator switch. Everything is missing from the left switch assembly apart from the contact pad. I had thought that i would be able to make something up myself but see that it is potentially quite complex.
The part number for the whole switch assembly is 233-83973-00-94. When i did a fruitless google search for this part, i discovered that there are many switch assemblies that have the 83973 bit of the part number. Does anyone know if the inerds of another switch with the same middle part of the part number might fit in my assembly?
Failing that, does someone have a left switch assembly. And failing that, can someone send me a picture of how the assembly fits together so i can try to make something.
And yes, i can see that one of the wires needs re-soldering...
Left switch assembly indicator assembly 12 Oct 2017 14:59 #2
  • Justind511
  • Justind511's Avatar
  • Open Class
  • Open Class
Left switch assembly indicator assembly 12 Oct 2017 15:00 #3
  • Justind511
  • Open Class
  • Open Class
There's one on eBay not too expensive
Left switch assembly indicator assembly 13 Oct 2017 00:34 #4
  • Chajoma
  • Novice
  • Novice
Thanks. However I am in the UK so there's a $50 shipping charge :(
Left switch assembly indicator assembly 13 Oct 2017 02:05 #5
  • rodent
  • rodent's Avatar
  • Sportsman
  • Sportsman
^^^Did you attempt to contact the seller? Postage cost might just be a generic figure.
If you don't ask, you don't get ;)
Last Edit: by rodent.
Left switch assembly indicator assembly 13 Oct 2017 02:27 #6
  • Chajoma
  • Novice
  • Novice
Good point - will do
Left switch assembly indicator assembly 13 Oct 2017 06:06 #7
  • Site Contributor
  • Site Contributor
I have a box of old switches... I will check this weekend. Can you post pics of what the outside looks like? Or any identifying marks? What functions it has? (horn, turn, etc.) Wiring connectors at end of harness?
Left switch assembly indicator assembly 13 Oct 2017 06:23 #8
  • Chajoma
  • Novice
  • Novice
Thanks Mark. A couple of pics below. It does full/dip lights, turn and horn
Left switch assembly indicator assembly 15 Oct 2017 09:21 #9
  • Chajoma
  • Novice
  • Novice
Any luck Mark? I've found one on ebay which ends tomorrow so will bid on that if you can't find one.
Left switch assembly indicator assembly 15 Oct 2017 10:04 #10
  • Site Contributor
  • Site Contributor
Switches/electrical for the 125/175 are in storage at my place about 80 miles from here... I have a tote full of stuff so likely I have something. Going there this afternoon. Should be back by 8pm PST or hopefully sooner.
  • Page:
  • 1
  • 2
Powered by Kunena Forum
