Welcome, Guest
  • Page:
  • 1
TOPIC: LT2 wiring Diagram
LT2 wiring Diagram 20 Aug 2017 19:39 #1
  • ara
  • ara's Avatar Topic Author
  • Newbie
  • Newbie
was wondering if anyone has LT2 wiring diagram, tech library has other 72's but not LT. I have one but it doesn't match to bike, not sure if wrong diagram or like most of these old manuals, not 100%. thanks
LT2 wiring Diagram 20 Aug 2017 21:25 #2
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
Found one here. www.slimduck.com/lt2-wiring.html
Hope it works as looks not too bad from where i'm sitting. Is there a problem we can help with. Can't help myself sometimes, but plenty of knowledgeable people on here with answers.
LT2 wiring Diagram 20 Aug 2017 22:22 #3
The 71-73 100-175cc combined Factory Service manual in the Tech Library is the only place I've ever seen a copy of the LT2/LT3 wiring diagram...
(It's there... you just have to hunt for it... Yamaha played "hide and seek" with a lot of the information and specifications in the Service Manuals. :Ugh )
LT2 wiring Diagram 20 Aug 2017 23:11 #4
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
Sorry, same as above & in my link. Little bit blurry but!!. I hate trying to follow wiring diagrams.
The following user(s) Liked this Post: Makotosun, MarkT
Last Edit: by RT325.
LT2 wiring Diagram 21 Aug 2017 20:49 #5
  • ara
  • Newbie
  • Newbie
Thanks folks for the diagram, apparently I had an Lt2 diagram, and just knowing it, makes the process a lot easier, you are not doubting it every step.
I am working on the indicator/horn/light switch.
First I didn’t realize, the diagram is separating in to two switches, indicator (3 wires) and light/power (4 wires)
Second I had the color version, so had to get over the fact that some colors don’t march the wording, ie green wire but shows yellow.
Third, in the diagram the black wire going into the switch is throwing me off, I am kinda sure it is just ground and there is no actual black wire going to the switch itself. But normally in such situations the diagram wouldn’t be drawn like that.
Anyway, I am going with the assumption till things go wrong. Will test it tomorrow. Again thanks for the great and quick help.
Was looking for used headlight and its chrome trim (bezel), it seems these are not as available as later DTs, would any other model’s or year’s fit on the LT headlight bucket? Shouldn’t the headlight be universal anyway? a DT175c headlight wouldn’t fit
For seat foam/cover, any recommendations or just ebay it?
Again thanks
LT2 wiring Diagram 21 Aug 2017 21:08 #6
Yes, the black wire to the handlebar combo light/horn switch is misleading... It was drawn that way because the switch housing must be grounded for the horn to work.
(Horn has brown + wire to one side and pink to horn button on other side... Pressing the horn button connects the pink to the switch housing which has to be grounded to the bars which has to be grounded to the triple clamps which have to be grounded to the frame.)
LT2 wiring Diagram 10 Feb 2019 14:43 #7
  • Ironranger88
  • Ironranger88's Avatar
  • Newbie
  • Newbie
I Wanted to put my Wiring modification on here too.. I edited the wording and colors to be more clear
The following user(s) Liked this Post: DT100comox
Last Edit: by Ironranger88.
LT2 wiring Diagram 11 Feb 2019 09:03 #8
  • ara
  • Newbie
  • Newbie
thanks
  • Page:
  • 1
