Rear Tire fit?
03 Aug 2020 15:31
RT3Sam
Sportsman
Sportsman
More
Rear Tire fit? #1
So a buddy of mine gave me a set of knobby's for my RT3 But the rear tire is a 110/100-18, which is about a 4.50 - 18. Will that fit my RT3?
03 Aug 2020 15:48
Pedalcrazy
Open Class
Open Class
More
Rear Tire fit? #2
If you still have the stock 4.00 X 18 on the bike then just look around and see if another 1/4 inch on each side will cause an issue. Seems like people have said it will fit. I know it is pretty tight clearance up at the front and maybe have to loose the chain guard? Just look at your existing clearance. A 4.5 will take another 1\4 inch on each side....plus mud if you are so inclined....
The following user(s) Liked this Post darinm, RT3Sam
04 Aug 2020 07:02
RT3Sam
Sportsman
Sportsman
More
Rear Tire fit? #3
Pedalcrazy wrote: If you still have the stock 4.00 X 18 on the bike then just look around and see if another 1/4 inch on each side will cause an issue. Seems like people have said it will fit. I know it is pretty tight clearance up at the front and maybe have to loose the chain guard? Just look at your existing clearance. A 4.5 will take another 1\4 inch on each side....plus mud if you are so inclined....
So I installed a Shinko 244, and I'm thinking the Kenda knobby I have to install might have knobs that stick out a little further. So I'm not sure i will be comparing apples to apples.
