Gauge of wire for DT3 Signals
25 Apr 2020 05:07 25 Apr 2020 05:28 by jmagda.
jmagda
Sportsman
Sportsman
More
Gauge of wire for DT3 Signals #1
Does anyone know the gauge of wiring for the turn signals on a DT3? Within each stripped wire, there are 7 strands. Each strand measures .32mm in diameter. Twisted together it's around .90mm. So, what gauge wire should I buy as a replacement? There is no writing on the sheath of the wires. I take that back; one wire reads "SWC SHOA 1972". I take it that was the company's name who manufactured the wiring back in '72 for this '73 bike.
26 Jun 2020 16:43
Jools
Mini Enduro
Mini Enduro
More
Gauge of wire for DT3 Signals #2
Probably equates to around 1.5mm squared
The Older I get the Better I was !
1978 TZ750E, 1991 TZ250 3YL, 1973 DT3, 1991 TZR250 3XV
1989 TZR250 3MA, 1986 TZR250 2MA, 1983 RZ350 YPVS
1981 RD250LC, 1973 RD350, 1998 YZF R1, 1993 FJ1200
26 Jun 2020 19:32 26 Jun 2020 19:41 by JayB. Reason: Correct a sentence.
JayB
Site Supporter
Site Supporter
More
Gauge of wire for DT3 Signals #3
Seven 0.32mm wires is equivalent to a 20 gauge wire.
0.32 mm / 25.4 mm/inch = 0.0126 inches diameter which is 28 gauge according to:
www.nehringwire.com/solid-wire-gauge-table/
Then use the following calculator with quantity of 7 of 28 gauge wires to find the answer is 20 gauge equivalent:
www.wirebarn.com/Combined-Wire-Gauge-Calculator_ep_42.html
26 Jun 2020 19:34
JayB
Site Supporter
Site Supporter
More
Gauge of wire for DT3 Signals #4
Why do people become engineers?
26 Jun 2020 19:35
JayB
Site Supporter
Site Supporter
More
Gauge of wire for DT3 Signals #5
Because they don't have enough personality to be undertakers.
The following user(s) Liked this Post 2fishkev
01 Jul 2020 03:31
jmagda
Sportsman
Sportsman
More
Gauge of wire for DT3 Signals #6
I've found places where the consensus seems to be 18 gauge. And VintageConnections.com agreed.
01 Jul 2020 04:34
mike8162
Site Supporter
Site Supporter
More
Gauge of wire for DT3 Signals #7
I used 18 ga. wire for a set that I rewired a while back. Grey for the fronts and black for the rears. I also put a piece of green and brown shrink wrap on the end near the bullet connector like the original wiring had. I always solder the ends after crimping them.
Cheers
