Thermal Flow Eyelet Codes
10 Oct 2019 22:20
PMK
Sportsman
Sportsman
More
Thermal Flow Eyelet Codes #1
Curious if anyone has a reference chart that shows the three digit shock eyelet code vs which year and model Yamaha the shocks came on.
Even better if the details such as shim stacks or different valve bodies were used.
Not super critical as I do have matching codes on several shocks.
12 Oct 2019 09:33
PMK
Sportsman
Sportsman
More
Thermal Flow Eyelet Codes #2
Maybe, we can make this easy.
If you have a bike with Thermal Flows on it, can you post tne model and year, then measure the shock extended length at full extension from bolt center to bolt center. Now the difficult part, on the upper shock eyelet, see if there is a three digit code and post that.
