DT3 Slight shake at road speed
09 Sep 2019 16:19
PigDoc
Novice
Novice
More
DT3 Slight shake at road speed #1
I took my DT3 out on the highway yesterday for the first time. So I was going 50 mph. What I noticed was a bit of shake really in the front. It wasn't terrible but noticeable. My question. I replaced the shock seals. The job went smoothly. The cylinders are perfect. I did replace the fluid with 30 wt. oil. It is more stiff than it was before, although I never drove the bike at road speed before I replaced the seals. I bought the bike and it was the first thing I did. The old ones were pretty leaky. The other note is that the tires appear new. They are Dunlop universal type treads. There is no evidence of any weights but on my new DT1 in 1971, I don't recall anything on the spokes or rims when I got it. But I was 16! So balance, shock oil weight...?
09 Sep 2019 17:58
KennyV
Site Supporter
Site Supporter
More
DT3 Slight shake at road speed #2
I'm guessing your front wheel needs to be balanced. If you have the one rim lock on the front wheel, that will throw the wheel out of balance and you can really feel it at 45+ mph.
71 Z50 Minitrail
72 RT2
74 250A
78 XT500E
06 F650GS Dakar
The following user(s) Liked this Post RT325, liferbiker
09 Sep 2019 21:14
liferbiker
Collector
Collector
More
DT3 Slight shake at road speed #3
I wondered the same thing as my wheel always drops to tirelock. You could put some weight 180 degrees from the lock just enough so it drops randomly. While spinning tire, make sure its round, maybe sat along time & developed a "flat spot". If thats the case, I can tell you a few methods to try.
10 Sep 2019 06:14
KennyV
Site Supporter
Site Supporter
More
DT3 Slight shake at road speed #4
This is what I did on my RT. When I first bought my XT and replaced the old tires, I noticed the wheel weights and the location in relation to the rim lock and valve stem. I left the weights on, and installed new tires and all was good, no sign of out of balance at highway speed.
After putting new tires on my RT it was obvious I had a front wheel out of balance once I got up to 45mph. So on the XT the wheel weights were on the forth and fifth spoke from valve stem, on the side furthest from rim lock. So I did the same on my RT. I started adding 1/4 stick on weights between the fourth and fifth spoke. I've added two weights and it's much, much better. Not prefect but close enough for me.
71 Z50 Minitrail
72 RT2
74 250A
78 XT500E
06 F650GS Dakar
The following user(s) Liked this Post Badger52
10 Sep 2019 13:38
Swoop56
Site Supporter
Site Supporter
More
DT3 Slight shake at road speed #5
Motion Pro do a lightweight aluminium rim lock , which is noticeably lighter
than stock unit . You then won't have to use as many weights to balance .
When I replaced the front tyre on my DT1 , I also replaced the rim lock
with a stock type . I has to use a humungous amount of weights to balance
the wheel . Next time I'm in there , I'll fit a Motion Pro unit .
The following user(s) Liked this Post DTfan, KennyV
11 Sep 2019 07:05 11 Sep 2019 07:13 by Don Dieago.
Don Dieago
Sportsman
Sportsman
More
DT3 Slight shake at road speed #6
I balance all my wheels and they are always out. my last one took 3.5 oz to balance. you can make a get buy balancer with a old swingarm You can do a semi decent job by jacking up bike and loosening up axle and do it on bike. You can get decent spoke weights off ebay or amazon but not cheep! you can get stick on cheep at harbor freight too. Im sure some will disagree but if you just drive on road and dont drive hard You dont need a rim lock at all. Removed One on my 400 rear only running one and haven't slipped a tire and I ride hard wheelie ever chance I get and sling gravel all day long. Now if I had a very aggressive knobby I would put it back on. front I not worried at all especially with a mild trials tire but without you have a goofey empty hole in rim
18 Sep 2019 05:24
DTfan
Mini Enduro
Mini Enduro
More
DT3 Slight shake at road speed #7
Hi Swoop56, can you let me know which one you bought, looks like there are a few options on their site?
18 Sep 2019 08:04
Swoop56
Site Supporter
Site Supporter
More
DT3 Slight shake at road speed #8
I wound up buying a Motion Pro Lite Lock 1.6 p/n 11-0058 ,
I haven't actually fitted it yet , but I figured being lighter than stock type ,
I won't have to use half the world's lead reserves to balance the wheel .
To be fair , I underestimated the weight of the rim lock , and put the tyre
splice by it , rather than back by the valve , making the imbalance worse .
