Steering help
14 Jun 2019 11:41
PigDoc
Novice
Novice
More
Steering help #1
I did this a long time ago. When I took the steering head off, upper head bearings went flying. Last time was 1971. But managed to find them all. Today its different. They bounced onto the concrete and into infinity. Can someone direct me on replacements? It would be greatly appreciated.
Charlie Francisco
14 Jun 2019 15:00
DEET
Moderator
Moderator
More
Steering help #2
It is usually a good idea to state which bike you are talking about.
If it is one of the early enduros, then they are usually twenty-two 3/16" on the top and nineteen 1/4" on the bottom.
14 Jun 2019 15:40
RT325
Collector
Collector
More
Steering help #3
Yep, as above but don't try to squeeze one more in as it won't work & you'll wonder why you can't steer it--i'm a learner again & lost my balance--just binds up as no room for the extra, maybe room for half a one, running clearance.
14 Jun 2019 16:28
MarkT
Site Supporter
Site Supporter
More
Steering help #4
And yes, in case you are wondering, they are inch sized and not metric like you might expect. Bicycle shops have them... good hardware stores... or bearing supply... amazon... lots of places.
Number of balls used changes on some models but Yamaha used 3/16" top and 1/4" lower on their bikes for decades.
14 Jun 2019 17:51 14 Jun 2019 18:01 by PigDoc.
PigDoc
Novice
Novice
More
Steering help #5
Sorry for not mentioning DT3. Kind of a panic, likely a flashback from 17! Back then it took quite a bit of effort to find replacement bearings in rural Illinois. I bought a demo 1971 DT1 demo in 71. I had it repainted in 72 with a GM dark brown metallic. For some reason I decided to take off retainer bolt after I had the headlight and wings off of it. I don't remember why? But I was 17 which explains a lot!
Today had the parts list and shop manual pages so saw 22- 3/16" top and 19-1/4" bottom. Awesome references. Local hardware in Champaign had both. So now completely disassembled, bearing and races de-greased and upper and lower head primed ready for paint. Only thing a bit rough is the set screw for steering damper. The head is pretty chewed. Final question, wheel bearing grease acceptable?
Charlie
PS: I wish I could find the high heat true satin paint I used to use for exhaust. Krylon is absolute garbage, from nozzle to sheen.
14 Jun 2019 20:00
apex
Content Contributor
Content Contributor
More
Steering help #6
I always use wheel bearing grease. Disc brake wheel bearing grease works great. Still using the same tub from 1992.
Allrighty Then
The following user(s) Liked this Post Rick C., PigDoc
14 Jun 2019 20:19 14 Jun 2019 20:23 by Rick C..
Rick C.
Collector
Collector
More
Steering help #7
Exhaust paint I use is Rust-oleum High Heat 2000 degree. Part number 248903 Flat Black on my "show bikes. "
Satin....REALLY??? !!!!
14 Jun 2019 21:57
RT325
Collector
Collector
More
Steering help #8
I should've said earlier, in my experience the bearing races get pitted or dented over time & replacing them as well as the balls make a nice job of it. At work, when parts were scarce & expensive i used to put the races up in the lathe with reasonably coarse sand paper on some tool i'd shaped up & force it against the race until it removed the dents. Worked good. Nothing worse than lumpy steering & bottom race suffers more probably due to all the weight being taken on it & not helped by doing big jumps & hard landings lol. All the new bikes, mostly small bikes with fork not fitted in the crate, came with steering head wound up that tight--by machine no doubt--that they were lumpy damaged straight out of the crate. Used to back them off a little but was realy all down hill from then on. That was very disappointing to find but never changed.
14 Jun 2019 23:41
liferbiker
Collector
Collector
More
Steering help #9
I've been using barbeque black for years on cars and bikes. it's flat, is cheap and stays
15 Jun 2019 15:01
PigDoc
Novice
Novice
More
Steering help #10
Thanks for heads up on the races. Will definitely check into it. Available?
Charlie
