73 DT3 electronic ignition conversion
11 Jun 2019 04:05
ejwangelin@gmail.com
Mini Enduro
Mini Enduro
More
73 DT3 electronic ignition conversion #1
73 DT3 electronic ignition conversion has anyone knowledge of Rexs kits for 74-75 Dt250? They state it wont fit the 73? Anyone tried it? I really want to do this to mine....help please?
11 Jun 2019 16:27
RT325
Collector
Collector
More
73 DT3 electronic ignition conversion #2
A late DT400 or the later DT250 CDI mag should still bolt on, the 3 hole type mounting. I had a similar set up on my RT2 for many years & was faultless plus no kick back. Didn't run a decomp either. Was my vintage mx bike. Actually to be honest come to think, it was a system i made up out of bits of this & that but end result equated to a late DT250 set up.
12 Jun 2019 01:12
Site Administrator
Site Administrator
More
73 DT3 electronic ignition conversion #3
In order for the Rex conversion to work, you need a CDI flywheel from a 74-76 DT360/400. Rex does not supply the flywheel, and their setup is specific to the later flywheels. When you order, if you do, make sure you have the correct flywheel, as there are several that look the same but are different. His site has the description and number to look for.
If you have the correct flywheel, his setup should work on any of the early 350/360 models.
The following user(s) Liked this Post Bigdog302
12 Jun 2019 01:36 12 Jun 2019 01:38 by RT325.
RT325
Collector
Collector
More
73 DT3 electronic ignition conversion #4
Makotosun means early 250/360 of course--I've just been outnumbered by woman drinking wine down the farm & need someone to pick on lol. sorry.
The following user(s) Liked this Post MarkT, Snglsmkr, Wheel mad
13 Jun 2019 23:36
Site Administrator
Site Administrator
More
73 DT3 electronic ignition conversion #5
RT325 wrote: Makotosun means early 250/360 of course--I've just been outnumbered by woman drinking wine down the farm & need someone to pick on lol. sorry.
Actually I meant the 74-76 flywheel.
( I think of the early 250/360 as from 1968-73. THOSE flywheels won't work with the REX kit.)
Only the 4 magnet versions used in 74-76. The 77-78 MAY work, but I would check with him before trying.
14 Jun 2019 01:06
RT325
Collector
Collector
More
73 DT3 electronic ignition conversion #6
Yep was just highlighting last line of post #3 earlier which was " 350/360 models" but i should stop being a smart arse sorry as obviously a typo.
Have good day. I'm not lol-- trying to get at the starter motor impossibly buried on my free VW Passat 4 motion. Makes working on DT/RT seem simple or at least accessible.
18 Jun 2019 13:03
Mini Enduro
Mini Enduro
More
73 DT3 electronic ignition conversion #7
Requires flywheel to be stamped FOTO1971 ... Anyone have one??????????
