AT1 charging help
16 May 2019 07:50
Scottddove
Open Class
Open Class
More
AT1 charging help #1
I posted this in the wrong place the first time I’m gonna try it here.
I really could use some help on this. I am trying to get this bike to charge. I have done all the testing procedures. I took my armature and stator to a shop that rebuilds starters and generators. He said my armature was no good. I purchased a whole new/different assembly off eBay that the seller said he would warranty if it didn’t work. Got it installed but it doesn’t appear to be any good either. I am just doubting I have 2 bad ones. I have new brushes, cleaned the armature real good, cleaned out all the little grooves, but it will only put out like 1.5 volts at 2000 rpm’s. I have the green wire off and grounded to the black wire the white wire taken loose and am testing for voltage on the terminal where the white wire would go. Am I missing something or do I just have two bad charging systems?
I have a limited time I can get a refund on the eBay purchase so I need some help quickly.
Thanks in advance. Captain Dave I need some of your wisdom.
16 May 2019 07:52
Scottddove
Open Class
Open Class
More
AT1 charging help #2
I did take the new to me armature to a motor rebuild shop and they verified it was good.
16 May 2019 11:12
MarkT
Site Supporter
Site Supporter
More
AT1 charging help #3
If you posted pictures of exactly how you hooked up your test connections it would help.
16 May 2019 12:27 16 May 2019 12:40 by MarkT.
MarkT
Site Supporter
Site Supporter
More
AT1 charging help #4
What you do to isolate the generator and test it separately from the regulator is completely disconnect the (A) and (F) wires from the generator... neither wire is connected to anything for the test... wrap them in tape .
Then you make up a jumper wire out of some spare wire and connect one end to the generator terminal F and the other end of your jumper wire to a good ground.
Start the engine and don't rev over 2,000 rpm. Use a voltmeter to see how much voltage you have at terminal A on the generator...
It's been a long time and I don't remember the wire colors on the AT that well... Using the picture Capt Dave posted a while back I've identified what I "think" are the wire terminals on the generator.
M = starter (goes to starter relay)
F = field wire for generator (goes to regulator)
A = Armature (goes to regulator)
I could be wrong so use this information at your own risk...
The following user(s) Liked this Post Makotosun, swm
16 May 2019 15:40
Capt.Dave
Collector
Collector
More
AT1 charging help #5
The black wire is E or ground.
Capt Dave
16 May 2019 18:23 16 May 2019 18:28 by Scottddove.
Scottddove
Open Class
Open Class
More
AT1 charging help #6
Success I cleaned up all the connections and hit each brush with a grinder to deglaze them and it all works great. Ok I am going to document my experience to help the next guy. Things I have learned. You can take a 69-71 stator and armature and use it on a 1975 dt125, be sure to use the correct Governor/advance they are different. I could have changed the points to the other side of the points plated and accomplished this as well. The difference is the key way on the armatures are not the same they are 180 degrees off which will result in not being able to get the bike in time. If you pull your points and put them on the other side you could overcome this fact if you wanted to go that route. The test procedure in the book for testing the charging abilities of the unit without the alternator attached is confusing to me anyway. MarkT does a good job of explaining it above. The Commutator has to be round and clean and the grooves in between clean of debris to work correctly also. A machine called a “Growler” can be used to check the armature, a place that rebuild electric motors/alternators will have one. I hope this helps someone in the future. I was actually fixing this particular bike for a friend, I may have to actually get me a AT1 now that I have became well educated on how they work. For you guys that responded and tried to help I really do appreciate it. I started this hobby 3-4 years ago now and had no bikes at all. I now have 14 and my 15 year old son has 5 we are really enjoying working on these old Yamaha’s. I was intimidating by the AT1’s but not now. Thanks again guys.
The following user(s) Liked this Post MarkT
16 May 2019 20:43
MarkT
Site Supporter
Site Supporter
More
AT1 charging help #7
Congratulations!
Yay2
16 May 2019 20:53
RT325
Collector
Collector
More
AT1 charging help #8
Good one, she charges at last. Sounds like you & son are hooked like the rest of us!!.
16 May 2019 22:14
Midlife Motor
Sportsman
Sportsman
More
AT1 charging help #9
You started this hobby 3-4 years ago with no bikes and now have over a dozen and 5 more for your boy? I gotta show this to my wife, you're making me look good with my six bikes in 4 years!
