Welcome, Guest
TOPIC: AT1 Carb Jetting
AT1 Carb Jetting 13 Apr 2019 10:15 #1
  • the2012
  • the2012's Avatar Topic Author
  • Novice
  • Novice
Hello to all,
Scratching my head about what the stock configuration the Mikuni should be set up with for the AT1. I received two different bodies, a VM24 and a VM26 with my bike, and a whole mess of slides, needles, airjets, etc.. The manual I have only references the body size, jet needle, and main jet. I've also looked through the technical references here with no luck.. (please correct me if i've missed something?) Any help figuring out the following would be very appreciated.
Bike: AT1 (not export, if that matters. Bike was bought in Korea.)
1. Airjet
2. Pilot Jet
3. Main Jet
4. Needle Jet
5. Jet Needle
6. Slide Cut-out
7. Needle valve
Again, any help figuring out stock specs would be hugely appreciated. Thanks in advance!
Chris
AT1 Carb Jetting 13 Apr 2019 11:26 #2
  • Site Contributor
  • Site Contributor
I'd recommend you check the full serial number to see if you have a 69-71 AT1 or a 72 AT2 or 73 AT3. All had the AT1 prefix stamped in the frame and engine.
Assuming you have a 69-71 AT1 the stock jetting for both the 24 (enduro) and 26 (MX) carbs is in the parts list in the Tech Library. The only problem is that the original carbs did not have a removable "air jet". So if your carbs do, they might not be original, they have been modified, you don't have a 69-71 AT1, or ???
(I think I'm going to stop responding to questions like this that don't include detailed pictures and full information like serial numbers as it's often a waste of my time.)
From the Tech Library:
AT1 Carb Jetting 13 Apr 2019 12:01 #3
  • the2012
  • Novice
  • Novice
MarkT,
Thank you for your help, and making the vintage world so welcoming. Sorry to waste your time.
AT1 Carb Jetting 13 Apr 2019 12:31 #4
  • Capt.Dave
  • Capt.Dave's Avatar
  • Collector
  • Collector
If your carb is an AT1 carb it will be marked 248 A2 on the flange. 150 main jet, 30 pilot jet, 2.0 slide, 4D3 needle N8 needle jet..
The following user(s) Liked this Post: asco, the2012
AT1 Carb Jetting 13 Apr 2019 12:43 #5
  • Site Contributor
  • Site Contributor
the2012 wrote: MarkT,
The comment wasn't directed specifically at you... and I didn't say you wasted my time.
The thing with this your question is none of the AT1 carbs had replaceable air jets... I don't think even the AT2 or 3 did... and there's just been so many questions with things like this that it wouldn't surprise me if you have a later reed valve bike or if the "box of carbs" turns out out to be Suzuki carbs or something. :)
And then what I posted would be a waste of time.
And you're welcome. I hope you figure it out.
AT1 Carb Jetting 13 Apr 2019 14:31 #6
  • asco
  • asco's Avatar
  • Site Contributor
  • Site Contributor
MarkT wrote: I'd recommend you check the full serial number to see if you have a 69-71 AT1 or a 72 AT2 or 73 AT3. All had the AT1 prefix stamped in the frame and engine.
MarkT,
Spends an incredible amount of time here answering questions. Personally, I couldn’t do what he does for two or perhaps more reasons. He has notes and files from thousands of posts, and he is more knowledgeable than me!
But if MARK spent that time on his own projects, he would be able to travel the world, working on bikes that actually paid real hard cash.
I applaud Mark’s efforts, he has to manage his time his way.
Hey Captain, it’s time to plan a fishing trip up north, at least one time on the same boat.
a
The following user(s) Liked this Post: Badger52, KennyV
YAMA-LAND
818-521-2109
MINIBIKESERVICE@AOL.COM 1971 125cc AT1-C (DOROTHEA) 1971 175cc CT1-C (BRANDY) 1970 250cc DT1-C (MONICA) 1973 100cc Hodaka Combat Rat (ABBY NORMAL) 1975 DT400 (BONNIE BELL)
Last Edit: by asco.
AT1 Carb Jetting 14 Apr 2019 08:50 #7
  • the2012
  • Novice
  • Novice
The non-replaceable air jet definitely had me scratching my head. I've only worked with one other set of Mikuni's on my Honda and I'll be honest, I thought I had stripped it trying to remove... so a weight off my shoulder there. What is *interesting* is that the two carb bodies I have are marked
-248A2
-248M2
Now, according to Capt. Dave, the A2 is the one that should be native to the AT1. However the A2 has a removed air-screw.. The M2 definitely has a pressed in air screw, so that's the one I will be putting back together with the specs provided.
Sincerely, thanks again for the help. Will post pics of the carbs and bits here shortly for those interested.
AT1 Carb Jetting 14 Apr 2019 08:55 #8
  • Site Contributor
  • Site Contributor
M2 is the ATMX carb code... should be 26mm.
AT1 Carb Jetting 14 Apr 2019 09:00 #9
  • the2012
  • Novice
  • Novice
Here are some of the guts that came in the box with the carbs.
AT1 Carb Jetting 14 Apr 2019 09:01 #10
  • the2012
  • Novice
  • Novice
and the bodies themselves
