Welcome, Guest
  • Page:
  • 1
TOPIC: 1968 YG5T stripped air screw
1968 YG5T stripped air screw 12 Jan 2019 09:37 #1
  • yamahahaha
  • yamahahaha's Avatar Topic Author
  • Site Contributor
  • Site Contributor
Finally got to the carb. Idiot me :EEEK instead of waiting to soak the carb I tried to muscle the air screw out. Air screw WON. What is the best way to remove it ??? Tap/Drill ??? Easy out ????Any recommendations on what size also
Last Edit: by yamahahaha.
1968 YG5T stripped air screw 12 Jan 2019 20:18 #2
  • mdscott
  • mdscott's Avatar
  • Site Contributor
  • Site Contributor
Try a propane torch, the slides on my CB500 carbs were completely stuck, heat did the trick.
Thanks Mark
Roseville, Ca.
'76 Bultaco 143 Frontera
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
1968 YG5T stripped air screw 14 Jan 2019 04:49 #3
  • yamahahaha
  • Site Contributor
  • Site Contributor
problem is even if I loosen it up there's nothing to grab onto to get it out ?????
1968 YG5T stripped air screw 14 Jan 2019 06:32 #4
  • Site Contributor
  • Site Contributor
I would try to use a dremel to make enough of a slot to get a little bite... that screw shouldn't be tight.
I'd try to boil the carb in water and see if you can get the screw to turn while it's hot. Maybe penetrating oil. Propane torch if careful... you can melt the carb body.
Last resort would be drilling... and if you do I'd get a new screw first... I think the head is big but the threads are tiny. I'd be afraid of ruining the carb completely.
1968 YG5T stripped air screw 15 Jan 2019 04:13 #5
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
Doesn't look like it applies in this case--but--i've seen air screws in carbs from rotary valve motors--can't remember if yamaha but--they had a drilling through the center of the screw to draw air in that way, still adjusted the same way. Have you had your motor running?, if it idles ok it might be best to leave it alone & just clean the jets etc--everything else that will come out.
1968 YG5T stripped air screw 15 Jan 2019 04:40 #6
  • yamahahaha
  • Site Contributor
  • Site Contributor
I've only had it running for about 2-3 seconds. I had put some fuel into the cylinder to see if it was going to fire. Like you said, I'm hoping it idles fine and I don't even have to mess with it.
  • Page:
  • 1
