Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: Fly-Wheel threads destroyed
Fly-Wheel threads destroyed 11 Jan 2019 11:12 #1
  • monel12
  • monel12's Avatar Topic Author
  • Site Contributor
  • Site Contributor
Anyone have advice as to how to get a flywheel off of a 1969 CT 1, where the threads are all buggered up?
When I tried to screw on the puller, it just pulled itself out.
1971 RT 1B
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
Fly-Wheel threads destroyed 11 Jan 2019 11:30 #2
  • asco
  • asco's Avatar
  • Site Contributor
  • Site Contributor
Left hand threaded puller must go on several turns until it stops.
The thread title should say “internal threads”
The puller needs to go back on — much deeper.
a
YAMA-LAND RESTORATIONS
818-521-2109
MINIBIKESERVICE@AOL.COM CUSTOM MINIBIKE (RALPH) 2002 110cc XR PAX RACING 1971 125cc AT1-C (DOROTHEA) 1971 175cc CT1-C (BRANDY) 1970 250cc DT1-C (MONICA) 1973 100cc Hodaka Combat Rat (ABBY NORMAL) 1969 125cc AT1-M MX (DELILAH)
Fly-Wheel threads destroyed 11 Jan 2019 12:08 #3
  • DEET
  • DEET's Avatar
  • Moderator
  • Moderator
Usually the first couple of threads are the problem.
Grind them off and go on to the deeper ones which should be good.
And, just to be sure, you know they are left hand threads.....
Yamaha@nc.rr.com
Fly-Wheel threads destroyed 11 Jan 2019 12:28 #4
  • monel12
  • Site Contributor
  • Site Contributor
Yes, I did thread on left handed, but I will try going even deeper. Thanks.
1971 RT 1B
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
Fly-Wheel threads destroyed 11 Jan 2019 14:39 #5
  • Capt.Dave
  • Capt.Dave's Avatar
  • Collector
  • Collector
I ground off the first couple of threads of my puller so it bottoms out.
Dave
Fly-Wheel threads destroyed 11 Jan 2019 15:21 #6
  • monel12
  • Site Contributor
  • Site Contributor
I did that with my old one, but could not get it turned down deep enough. Bought a new one, and still having problems turning it down. Just ordered a wrench to hold the flywheel in place while turning it down. Will see if that helps. Thanks for your input.
1971 RT 1B
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
Fly-Wheel threads destroyed 11 Jan 2019 15:29 #7
  • Schu
  • Schu's Avatar
  • Sportsman
  • Sportsman
You do have the center extractor bolt backed out all the way or better yet, removed so that it doesn't contact the end of the crank? Because that will prevent you from fully engaging the left hand threaded portion of the device.
Don't ask me how I know this........
Fly-Wheel threads destroyed 11 Jan 2019 16:34 #8
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
Make sure both washers are out--spring & thick flat washer to get the deepest engagement possible. & as said already back the bolt right back or can hit the crank before fully home in the reverse thread. Had to shorten my favorite puller as threads had just been used to much. Is a very deep puller so had plenty to play with. Actualy i think 'that one' i put 3 grind marks at the start of the puller to use as a "poor man" Tap to clean up the damaged flywheel threads where the puller fits. Been lucky so far but suppose when the time comes i'd try a two legged strong puller in the slots & hope for the best.
Fly-Wheel threads destroyed 11 Jan 2019 16:54 #9
  • monel12
  • Site Contributor
  • Site Contributor
I was thinking about a 2 legged puller also. If I can find one to fit....
1971 RT 1B
1971 RT 1B
1970 RT 1
1970 RT 1
1969 CT 1
1971 DT 1
1974 100MX
2016 BMW F700 GS
1982 Yamaha Towny
1971 CT 1
1975 DT400
Fly-Wheel threads destroyed 11 Jan 2019 18:04 #10
  • Site Contributor
  • Site Contributor
Be very careful with the two legged puller in through the slots. It's very easy to damage/destroy the stator coils under the flywheel... especially if the flywheel turns as you're tightening the puller.
:Buds
  • Page:
  • 1
  • 2
